03-04-2016, 06:33 PM | #1 |
Junior Member
5" flip kit and 2" shackles
Is this possible?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
03-04-2016, 07:46 PM | #2 |
Re: 5" flip kit and 2" shackles
Yes. My 74 & 90 are both done that way. On squares, the bed supports just adjacent to the rear shackles sometimes need to be trimmed for clearance depending on what length leafs are in the truck.
03-04-2016, 08:07 PM | #3 |
driving is in my blood
Dam, thats low. Me likey.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-04-2016, 11:35 PM | #4 |
Diggin The SquareLife
Yes it will work and you could even go lower
03-04-2016, 11:45 PM | #5 |
You'll bottom out beyond this point w/a standard c-notch cause the differential hits the bed floor.
03-05-2016, 10:04 AM | #6 |
Junior Member
Thanks for the info. Are you running a notch on your trucks?
03-05-2016, 12:48 PM | #7 |
I have the same setup on my 84 with the bed supports notched. I do not have a c notch in the frame. I just removed the factory bump stops. It has clearance.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
03-06-2016, 02:41 AM | #8 |
Mine is this way to but I think it is too low. You will need to take out the factory stops.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
03-06-2016, 03:15 PM | #9 |
Both had the factory bumpstops removed & utilized c-notches.
