1990 crew cab
I have two sensors one on each side of the block that gives the temp what are they called and where can I buy them the temp gauge doesn't work and I'm sure one is bad because I used a old one and it started working then that one went bad
Posted via Mobile Device |
Re: 1990 crew cab
Hi there, I never worked on a 1990, but worked on alot of older ones. Sounds like you are describing a coolant temperature sending unit. Strange you have two, but than again the older ones only had one. It's mounted closer to the front of the drivers side head.
Master Hater
Re: 1990 crew cab
Yep should have one in the front side of the drivers head that is for the gauge in the dash and one in the front of the intake manifold tells the ECM the engine temp.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
#4 | |
Re: 1990 crew cab
Hi There, I'm pretty sure you need a TS253T sensor. Get the parts guy to show you this one.
Master Hater
Re: 1990 crew cab
One is called the CTS or Coolant temp sensor for the ECM and the one for the gauge is called the Sender
Re: 1990 crew cab
Looks like ROCK AUTO shows 2 types for a 350...
one has a spade connector, the other a plastic connector... Take a look here and see if these look right! http://www.rockauto.com/en/catalog/c...+/+sensor,4748
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
Re: 1990 crew cab
If it is a 454 will have a third one on RH head that is for the cooling fan in front of condenser!
![]() 71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
| Bookmarks |
