OG gauges with 90ohm sender
Found this while cruzin the web. Have any of you done this on a s10 or other?
Jeff http://www.oldengine.org/unfaq/oddbits.htm
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
Re: OG gauges with 90ohm sender
This will work. The gauge will be slightly off at middle ranges but you probably won't even notice it. You don't have to solder the resistor at the sender. You can attach it at the instrument cluster or as part of the harness. That way if you need a replacement sender you can use a stock one without modifications.
Do you replace the wire with the resistor just splicing it in anywhere?
![]() Join Date: May 2007
no, that would be putting the resistor in series, and would not work.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
The resistor must "Tee" off the sender wire and connect to ground. When done correctly there will be two connections t make:
---------------/\/\/\/\----GND | |__________Sender________GND |
