Old 03-04-2016, 11:06 PM   #1
Lowenuf
Lowenuf's Avatar
Optional overload spring
Just curious.....
My LWB '72 has the optional overload spring/brackets on both sides. I will soon be doing a 3/4 drop, and was wondering if I need to remove all of this, or just warm up the springs and bend them upwards away from the stops the same distance as stock, after the lowering?
I will not be towing with the truck, nor ever hauling anything of heavy weight...
Thanks....
Lowenuf is offline   Reply With Quote
Old 03-04-2016, 11:36 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Optional overload spring
Originally Posted by Lowenuf View Post
Just curious.....
Thanks....
If you aren't going to tow or haul heavy loads I would just remove them.
LockDoc
Leon
Old 03-04-2016, 11:43 PM   #3
Lowenuf
Lowenuf's Avatar
Thanks.
Old 03-05-2016, 12:53 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Optional overload spring
I removed mine and sold them as soon as I listed them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-05-2016, 02:00 AM   #5
OregonNed
OregonNed's Avatar
Yanked mine too and tossed them in the car port
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-05-2016, 08:15 AM   #6
frenchy51
frenchy51's Avatar
I'm doing the same drop now on my C10 and I'm removing them. Even with no drop they made noise on small bumps from contact.
Gives me an excuse to restore my C20 for heavy loads.....
frenchy51 is offline   Reply With Quote
Old 03-05-2016, 08:29 AM   #7
ettsn
ettsn's Avatar
I've got them, and I'm about to drop mine. Was gonna just chuck them, but would someone else want them?
ettsn is offline   Reply With Quote
Old 03-05-2016, 11:50 AM   #8
tommys72
tommys72's Avatar
Anyone have a picture of said springs ?
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 03-05-2016, 12:19 PM   #9
LockDoc
LockDoc's Avatar
There are a couple of styles.
http://67-72chevytrucks.com/vboard/s...d.php?t=676334
http://67-72chevytrucks.com/vboard/s...d.php?t=678980
LockDoc
Leon
Old 03-05-2016, 12:30 PM   #10
Coley
Coley's Avatar
I think there were (2) types of overload springs depending on whether the truck came with a leaf spring or coil spring rear end.
Lock doc shows some excellent pics of the coil spring overloads.
The leaf spring overloads are different in that there might be a forward and trailing 'rub' bracket riveted to the frame that the overload leaf would ride up against under heavy load.
That said, I picked up a pair of the cantilever type for my 1/2 ton coil spring truck....I'm addin' em, rather than subtracting them at this point.
Now, with a 3/4 drop or a 2/3 drop would they rub? does anyone have theirs mounted and could they measure up the 'free' gap?
Interested.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 03-05-2016, 01:44 PM   #11
Lowenuf
Lowenuf's Avatar
my set is like in LocDoc's second picture, and they are listed on the SPID sheet .....
