Old 03-05-2016, 12:18 AM   #1
HOTFUN
HOTFUN's Avatar
My 66 C10 has new paint
Haven't posted for a while with many irons in the fire but the 66 is maybe going to see the streets this summer. A week of color sanding and polishing and the new bed wood can be installed. I assembled all the sheet metal to verify alignment and fit and painted it together to avoid any panel color mismatch. Now it comes back apart for the hardware and weatherstrip. The cab and complete front end minus the hood was from a rust free and dent free 60k mile 1966 C30 camper from Kansas so it was a dream build original floors, rockers, and cab corners. Even the cab over camper with about 1 inch clearance above rood panel provided a perfect rust free and dent free roof. How many 60's trucks still have the original factory gutter seam sealer in place that was just a flawless time capsule. Had to add the big back window since it had started its life with a camper access hole cut through the cab back panel anyway. Factory air and Custom Cab too. Hood had been walked on from cleaning the camper window but a mint original paint hood was found from a local shed stored C60 farm truck that created the perfect addition to the rust free clip. The tailgate was a brand new 66 take off and the box was a mint original Arizona rust and dent free fleetside swb under an old camper shell. She is sweet.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 03-05-2016, 12:41 AM   #2
Captainfab
60-66 Nut
Re: My 66 C10 has new paint
Very nice
Old 03-05-2016, 02:04 AM   #3
LT1 Burb
LT1 Burb's Avatar
Looks awesome Mark, I am green with envy.
LT1 Burb is offline   Reply With Quote
Old 03-05-2016, 02:05 AM   #4
Haaland
Beautiful truck! Nice find on the tailgate.
Haaland is offline   Reply With Quote
Old 03-05-2016, 10:18 AM   #5
BFoley
BFoley's Avatar
Love the color combo. What are they?
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 03-05-2016, 10:42 AM   #6
chevy2tom
chevy2tom's Avatar
Looks great!
chevy2tom is offline   Reply With Quote
Old 03-05-2016, 10:53 AM   #7
Mathew21
Mathew21's Avatar
I love it, Nice job.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 03-05-2016, 12:06 PM   #8
oem4me
Sooo nice! The finish line is within sight now. That surely must motivate a bit.
The saddle paint looks great! Well done Mark. Are you squirting the paint yourself? Just curious how you did your tailgate letters. I've been contemplating making a rigid masking die or template for that purpose to mimic the factory look.
Old 03-05-2016, 12:46 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Beautiful
66 C20 Service Truck:
Old 03-05-2016, 02:41 PM   #10
HOTFUN
HOTFUN's Avatar
Thanks everyone. I know I have been watching LT1 burb as we seem to have the same busy schedule so our trucks are about on the same assembly line.
Its my old 1st body shop building that I still own but my buddy Joe is the custom painter these days. It's a PPG base clear and their version crossover of the oem formula of code #555 saddle gold and the GM white. That said a clearcoat paint makes it look like an ice coating when it is sanded and polished so the color is close but far superior for gloss than a oem factory laquer job in the day could ever be. I also believe it makes the metallic POP and create more of a fawn color than what the 60's saddle gold appeared like. I have so much NOS to go on this truck as all the trim, grille, bezels, emblems, tailgate hardware, even the vent windows were new old stock GM. Floor mat and seat cloth was also NOS along with steering wheel ring and cap. Even have a NOS whitewall spare date coded 1965 mounted on the wheel to set up in the bed with 5 NOS hub caps. But I built it to enjoy so it will be driven down the interstate on nice days.
'72 GMC K2500 4x4
Old 03-05-2016, 03:02 PM   #11
HOTFUN
HOTFUN's Avatar
Bruce, I'll tell you the secret to making those tailgate letters really correct in paint and what GM would have tried to make their line stencil painting to have it come out like. First I get a set of black vinyl CHEVROLET letters and then I paint the ivory base color over the center area of the tailgate stamped lettering. I also tape off and paint the area between the chrome mouldings at the same time. Let it dry long enough to install the vinyl letters where I want them. Then spray the body color over the entire truck as uniformity between panels especially with metallic paints is what I look for. After the base color is flashed off, I remove the vinyl lettering carefully and they come off easy if you dont bake your base color in the booth. I then shoot all the clear coat over the panels and it just melts the two colors together like it was under glass. If you wonder why I said to use "black" vinyl letters it is because you can see the finished look so much easier where the letter will line up on that newly sprayed white strip of color. Thanks, Mark
'72 GMC K2500 4x4
Old 03-05-2016, 04:58 PM   #12
TJ's Chevy
TJ's Chevy's Avatar
VERY NICE!!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-05-2016, 10:48 PM   #13
LT1 Burb
LT1 Burb's Avatar
Funny thing Mark, we pretty well have the same builds going but 1 year apart. You will have more NOS parts but we will maybe have the only 2 555 trucks running NOS grills. I am just finishing up blocking with 600, hoping to be in the booth in a few weeks.
PS, am stealing your vinyl letter ideal, have been wondering how I was going to do that.
Old 03-05-2016, 10:59 PM   #14
Classic v6 GMC's
Classic v6 GMC's's Avatar
Very nice and love the color!!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
