3" lowering blocks?
I want to make a set of lowering blocks for the back of my '66 C10. I see people with 2" ones but I was thinking 3". Anyone ever do 3" blocks? Any reason not to?
Thanks- John
'59 Apache, short Fleetside, work in progress. |
Re: 3" lowering blocks?
Hi John
It depends upon where your scrub line is, if you imagine letting all the air out of your tires so the truck is sitting on the rims then anything below this will hit the ground first. Your scrub line on 15" rims is about 7 1/2" from the centre line of your axle, so if you add half the width of your axle tube which is 1 1/2", plus 2 3/4" of control arm, then 3" of lowering block and 1" of nuts and lower shock mount, (1 1/2 + 2 3/4 + 3" + 1" = 8 1/4) you'll be at 8 1/4", if you get a rear puncture your suspension will hit the road before your wheel rim and "jack" your truck. A bigger diameter wheel will increase this, so (for example) you'd have 10" to play with on 20" rim. Cheers - Ian __________________
Getting old sucks.............but it sure beats the alternative |
I didn't think of that. I have 15's so better not go 3". Thanks for the help.
-John
Porterbuilt has adjustable trailing arms with 1" or 3" built in. Helps push the rear back into center of wheel well. As an alternative.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#5 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
