Old 03-05-2016, 04:31 PM   #1
Born Lucky
rear end swap
Ok getting close to swap. I just sold the Eaton HO52.
Now I want to go 5 Lug, and I have donor part ( off a 1973)
I also have a donor part from a 71 ,6 lug.
I want to know if I can use my 71 housing with my 73 axles.
(Both units are 3:08)
This would make it a direct bolt on. No Fab no welding.
What do you think?
Born Lucky is offline   Reply With Quote
Old 03-05-2016, 04:58 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: rear end swap
71 12 bolt will be 5 lug not 6.
You will need to have the same length axles and spline count as well
You can just have the 6 lug axles redrilled.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-05-2016, 08:21 PM   #3
Born Lucky
Re: rear end swap
I HAVE TO CHECK THE 6 LUG
Old 03-05-2016, 09:17 PM   #4
AtomicYJ
AtomicYJ's Avatar
Re: rear end swap
'71 4x4 12 bolt will be 6 lug. Not sure if the 4x4 axle is wider or not, but '73+ it is.
1957 Chevy 3200
1971 Jeep CJ-5 Renegade II
1983 Chevy K/10 Silverado
1985 Jeep CJ-8 Scrambler
AtomicYJ is offline   Reply With Quote
Old 03-05-2016, 09:49 PM   #5
vince1
Re: rear end swap
I don't see why not if the housings are the same width and splines the same. I also have a 71 with 6 stud axles. Apparently they changed mid-year from 6 stud to 5 stud. Aside from stud count, what are the differences between the 71 and 73? I would have thought they might be the same. If the bearing surfaces are good maybe don't throw out those 6 stud axles. Somebody would love to have them.
vince1 is offline   Reply With Quote
Old 03-06-2016, 12:17 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: rear end swap
The difference is in 71 they had coil springs and in 73 went to leaf springs. 71 72 rear diff is bolt in and the 73 is not
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-06-2016, 01:29 AM   #7
Captainfab
60-66 Nut
Re: rear end swap
A 12 bolt from a '71-'72 C10 will be 63.5" wide and have the 5 x 5" wheel stud pattern. Also most will be setup for the trailing arm suspension. A 12 bolt from a '71-'72 K10 should also be 63.5" wide, setup for leaf springs, but the wheel stud pattern will be 6 x 5.5". The '73-'82 C10 12 bolts will also be 53.5" wide and have the 5 x 5" wheel stud pattern, but will be setup for leaf springs.
Old 03-07-2016, 06:50 PM   #8
Born Lucky
Re: rear end swap
I was looking at the 1973 axle seat and it is almost the same length as the 1971. I was wondering if welding a longer plate with holes ( u bolts) and the 73 axle seat can work?
Old 03-08-2016, 01:03 AM   #9
Captainfab
60-66 Nut
Re: rear end swap
The '73 is setup for leaf springs and I doubt that the leaf spring pads are the correct center to center spacing. Why not do it right and cut those off and weld on the trailing arm mounts? Your are also going to have to weld on a panhard bar mount.
Old 03-08-2016, 07:22 AM   #10
Born Lucky
Re: rear end swap
Yeah you are correct. Do it right the first time
Thank you you are very helpful
Old 03-08-2016, 10:47 AM   #11
patrickk1
Re: rear end swap
Out of curiosity, Why did you decide to get rid of the eaton?
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 03-08-2016, 11:18 AM   #12
Born Lucky
Re: rear end swap
I wanted to go 5 lug.
The rear end is funding the build.
Old 03-08-2016, 12:16 PM   #13
Chevy Fleetside
Re: rear end swap
They make Bolt on pan nard bar mounts but I could only find them for the Ford 9".
Old 03-08-2016, 01:21 PM   #14
PGSigns
PGSigns's Avatar
Re: rear end swap
Any of the log panhard bars us a bracket the goes on the trailing arm so no need to weld one on. The less heat you pt on the housing the better.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
