Fan options
Looking for electric fan options for my 62. 350 SB, 4 speed, 3 row champion aluminum radiator. New or pick n pull.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Fan options
Re: Fan options
Go with the Lincoln Mark VIII or the Mercury Cougar XR-7 fan. They really do the job well.
Re: Fan options
I've had good luck with a dual fan with shroud from a 2006 Saturn Vue.
http://67-72chevytrucks.com/vboard/s...d.php?t=682168
1964 C10 Fleetside Long Bed |
![]() Join Date: Jun 2011
Re: Fan options
i went to so cal. got the Champion 4 core. then a shroud and pusher fan. works so good the fan hardly ever comes on.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
![]() Join Date: Mar 2005
Re: Fan options
Is there a particular reason why you want to go electric?
Here's my take on fans: A good 7 blade clutch fan and a stock shroud will vastly outperform an electric fan. I live in the desert of Southern California at 3000ft of altitude where it gets over 100 degrees in the summer for weeks on end, and all I use are clutch fans and have never had overheating issues, even on small block 400s. I see a lot of guys shun the factory stuff and go electric because they have an engine that runs hot and the first place they look at is the fan. Usually that's not the culprit! It's TIMING. An engine with too little initial timing will run hot because the burn is happening early and causing the engine to heat soak. Keep your initial timing between 12-16 degrees, with total of 34-36 degrees. You will be amazed at cool the engine runs. Just food for thought. If you're going electric because you're crunched for space, I totally understand. There are some times when a clutch fan and a shroud just aren't an option because the engine is so close to the radiator.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#7 | |
Re: Fan options
Re: Fan options
I think it's your best option if you want simplicity and functionality. The factory stuff works really well.
Re: Fan options
if you dont care about loseing a lil bit of HP go with a fan and clutch ... if you want to squeeze out every drop of HP go with a electric fan .. but dont use the fan from champion they are junk i know i used it and it would not cool had to use a different fan
#10 | |
Moderator
Re: Fan options
Re: Fan options
I used a Spal fan. So-Cal said it was the best brand on the market for electric. its loud turns 2,370 rpm but rarely turns on.
Re: Fan options
CorvetteJim,
Are your lower radiator saddle mounts on the upper or lower position? Photos look like they are in the lower position but I can't tell for sure.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#13 |
Re: Fan options
I also went with the Lincoln Mark VIII electric fan. MY 64 has Vintage air and when idling in 114+ deg heat with the A/C on my temp would slowly climb. If I revved the motor the temp would drop. I picked up the Mark VIII on 1/2 off day at Pick N Pull and a Volvo relay again from Pick N Pull but I also had to get a temperature switch from Summit to turn the fan. The most expensive part was the Derrels switch from Summit I think it was $36.00 The Lincoln fans fit like they were made for our trucks. Heck even my radiator overflow/windshield washer setup came from Pick N Pull on 1/2 off day. I'm CHEAP & Lazy!
#14 |
Re: Fan options
Flex-a-lite Black Magic #188 3300cfm no issues on my 4x4 and fits perfectly on 1962 radiator. Las Vegas heat and all. You get what you pay for. I opted for quality of a new fan.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#15 | |
Re: Fan options
#16 |
Re: Fan options
The Volvo relay controls 2 speed option..............read these threads..........
http://www.syty.net/forums/showthread.php?t=99248 http://www.jeepforum.com/forum/f12/v...-swap-1373350/ http://www.blueovalfanatics.com/foru...ad.php?t=22073 http://www.bimmerforums.com/forum/sh...Fan-Conversion
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#17 |
Re: Fan options
WOLFMANmike,
Actually the Mark VIII fan I bought was only a single speed fan. It did have 3 wires running to it but there was no middle terminal at the fan motor. From what I've read Lincoln had both 2 & 1 speed fans depending on what year Lincoln you got the fan from. Before removing my fan I tested it with my 18V DeWalt cordless drill battery using a couple of cheep Harbor Freight jumper leads. I'll get back to you on the Volvo relay and the Derell switch I used and the part numbers. I've got all this stuff written down in my note book and now of course I can't find it. I did all this a few years ago but I know I kept my notes. |
#18 |
Re: Fan options
derell = derale
#19 | |
Re: Fan options
#20 |
Re: Fan options
#21 |
Re: Fan options
i believe lower.I had to cut off one end of the lower mounts to accommodate the thicker Champion radiator and move them about an inch. turned out great
#22 |
Re: Fan options
A simple trick to hep out a mechanical fan is to seal the shroud to the radiator. In my case an old rear window seal fit perfectly. I just pressed the the shroud into the channel.
#23 |
Re: Fan options
Thanks I need to devote a little more time to it....trans needs replacing now....
#24 |
Re: Fan options
