Old 03-05-2016, 08:21 PM   #1
Coach
Coach's Avatar
Front or rear sway bar?
Looking for opinions on what is more beneficial, a front or rear sway bar? Currently have a 3" drop in the front and 5" drop in the rear. Trying to eliminate some of the body roll to handle better in turns. All suggestions would be greatly appreciated.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 03-05-2016, 08:23 PM   #2
bigrigpardo
Re: Front or rear sway bar?
both. bigger front than stock will help a lot and a rear will also help.
bigrigpardo is offline   Reply With Quote
Old 03-05-2016, 08:25 PM   #3
Possmguts
Possmguts's Avatar
Front more than the back... but both would make it handle real nice...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-05-2016, 09:41 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Front or rear sway bar?
Put the front one on first and see what you think! I don't think you will spend the money on the rear after you drive it unless your building a auto cross truck then you may want the rear too!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-05-2016, 10:11 PM   #5
67 chevelle
67 chevelle's Avatar
front is way more important , i could not believe it went i first found out my 67 came without one , i quickly acquired one , for vastly improved drive ability
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-05-2016, 10:22 PM   #6
Possmguts
Possmguts's Avatar
The cheaper way out is to find one from a one ton truck and just buy the mounts and bushings... its a thick bar and will mount really easy..
Old 03-05-2016, 11:34 PM   #7
Mrturner1
Did you find and paint that one?
Mrturner1 is offline   Reply With Quote
Old 03-06-2016, 12:53 AM   #8
Possmguts
Possmguts's Avatar
Yes.. I found it from a member on here... little grinding and sanding and a couple coats of ceramic paint and its looks new. Got it for 50 bucks.. and found the mounting hardware for 35 on Ebay
Old 03-06-2016, 07:47 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
You can use the front sway bar from any 73-87 Chev or GMC pickup. There are different sized front sway bars with the biggest being on the real heavy duty C20's and GMC 2500 with the 9000b + GVW rating. The biggest on the 73/87's trucks is the 1 1/4" front sway bar and once installed you will not believe the difference in handling. Seeing your truck is lowered you will want to get the front brackets for lowered trucks. Various vendors have them and I got mine from ECE in Fresno. The posted link is great showing the install process.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-06-2016, 08:31 AM   #10
BugzC10
BugzC10's Avatar
X2
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-06-2016, 12:04 PM   #11
NGN
NGN's Avatar
I used one off the front of another C10 for my 67 short , big difference . Which made me right away wonder why they didn't find it important enough to put them in from the start.
NGN Nick
NGN is offline   Reply With Quote
Old 03-06-2016, 12:29 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
You'll notice the difference in a front sway bar in everyday driving. A rear... you'll have to "get into some corners" at higher speeds to really notice it. You probably won't notice a rear sway bar under every day driving conditions. At a track, yes.
I can't remember the size at the moment, but I put on the largest one, I think 1-1/4".
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-09-2016, 12:16 PM   #13
68 P.O.S.
I bought a front end rebuikd kit and 4/6 drop kit from ECE. Decided to buy sway bars while I was at it. The front bar is from ECE (1 1/4") and the rear sway bar is from CPP (1 1/8"). After installing the drop and front end rebuild kits I had a ton of tire rub on the front inner fenders in all driving conditions. I first installed the front sway bar and drove it for a week. The tire rub was greatly reduced and handling was improved a good bit, nothing spectacular, but a helluva lot better. When I added the rear bar the tire rub was almost eliminated and now the long bed drives almost like it's on rails. For me, both sway bars together were a fantastic upgrade and would do it again in a heartbeat.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
