03-05-2016, 11:36 PM | #1 |
Pics of your B&M floor shift custom consoles
Hey all, I got a light truck megashifter and I don't like the plastic thing that comes with it. Would like a couple cup holders if possible.
Please tell the materials you used as well, thanks guys |
03-06-2016, 12:07 AM | #2 |
Re: Pics of your B&M floor shift custom consoles
This is how i did mine, I am using the same shifter
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
03-06-2016, 01:47 PM | #3 |
That interior looks very well done. I'm not a red guy, but dam that looks good.
1972 C10 - It might be old, but it's not slow |
03-06-2016, 02:27 PM | #4 |
Here mine, a long way from complete but getting there.
03-06-2016, 04:05 PM | #5 |
What are you guys making those out of?
03-06-2016, 04:56 PM | #6 |
really nice consoles you guys have
03-06-2016, 08:36 PM | #7 |
I made mine out of MDX, aluminum and fiberglass and a whole lot of time..
03-06-2016, 08:58 PM | #8 |
Mine is cut out of 3/8 plywood with 2x2 supports between. Covered with vinyl and used some dense foam to form shapes under it like the circles around the cup holders. Weld wood contact cement to glue it on. Leave a ridge on the side and build the top panel to fitdown in it. Don't get in a hurry, it's pretty tedious work. Vidmans is awesome. Mine turned out great for my first and I plan to make changes.
03-06-2016, 09:08 PM | #9 |
watching this one I'm putting a mega shifter shortly anyone doing one for bench seat with cup holders
03-06-2016, 09:18 PM | #10 |
Old member
Very nice guy's. I took my B&W shifter out and installed a S-10 shifter. Neither of mine are any where this nice.
The red toggle switch is for the AC compressor.
03-06-2016, 11:43 PM | #11 |
That's what I plan on doing. The fiance says if I get rid of the bench seat I'm in big trouble lol I got the light truck megashifter and the plastic consol that came with it is too long. Even butted up against the bench the front is up where the floor starts to hump up.
03-07-2016, 11:58 AM | #12 |
I don't think you could get cup holders in with the bench unless you made it go over the seat and removable when you needed the full seat. That could be done. The one I built is only 9" or so wide to give me leg room when I am driving. I did not want it up against my leg the whole time.
03-09-2016, 08:36 PM | #13 |
Pics of the shifter without the console
03-10-2016, 08:33 PM | #14 |
03-10-2016, 08:34 PM | #15 | |
03-10-2016, 09:01 PM | #16 |
I used dynamat, MLV and ACC carpet pad. I went up the firewall as far as i could and the the back of the cab. Should be pretty quiet...
