![]() Join Date: May 2014
Trailing arm to crossmember bolt size
I am replacing my trailing arms soon. The original bolts where the front of the trailing arm mounts to the cross member are very rusty and will need to be replaced. Does anybody happen to know the size of these bolts so I can get some beforehand?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Re: Trailing arm to crossmember bolt size
3/4" x4"
No problem I am just getting ready to install my new trailing arms and bought the grade 8 ones at tractor supply.
I kinda feel stupid asking this question now that I think about it. Some simple measurements of the busing insert and a glance under my truck I could've figured it out. Thanks again though!!
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Could we get another verification of size?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
The Older Generation
The above would be correct. If you wanted to get technical, The original bolt I have is 3 15/16 inches long from under the head to the tip of the threads and .747 diameter (3/4" is .750) LockDoc
