Old 03-06-2016, 07:00 PM   #1
bills59
Buying New 10067353 Crate Engine
I'm going to be ordering a new GM 10067353 350 crate engine next week and I need to know if there is something I have forgotten to order with it: Exhaust manifold gaskets, intake manifold gaskets, fuel pump gaskets and water pump gaskets.
bills59 is offline   Reply With Quote
Old 03-06-2016, 07:29 PM   #2
68c10owner
68c10owner's Avatar
Re: Buying New 10067353 Crate Engine
Carb gasket, distributor gasket, coolant, maybe some oil and a new filter for after camshaft break-in. These are great engines, just wish I had the cash to buy one for my truck.
EDIT- dont forget spark plugs. And this might be a good time for a new cap, rotor and plug wires.
Anthony
68c10owner is offline   Reply With Quote
Old 03-06-2016, 07:43 PM   #3
bills59
I see you are in Sacramento. Do you know any one reliable that can pull the old motor and install the new one?. I have a bad back and was going to have the dealership do the swap
Old 03-06-2016, 07:45 PM   #4
68c10owner
68c10owner's Avatar
Not around your area but I know of a shop or 2 around here but its a bit of a drive for you. Id give you a hand myself if you were closer.
Anthony
Old 03-06-2016, 07:50 PM   #5
bills59
Thanks, The dealer is in rural area and said he could do the swap for $800-1000 which isn't bad for a GM shop
Old 03-06-2016, 07:52 PM   #6
68c10owner
68c10owner's Avatar
Thats not a bad price for a dealer.
Anthony
Old 03-06-2016, 10:33 PM   #7
weider1717
I have never used exhaust manifold gaskets they come without and not needed unless they're warped.
I've have mine surfaced before to make sure then other times didn't never had a leak either way.
they're ugly also. toss them
weider1717 is offline   Reply With Quote
Old 03-07-2016, 12:48 AM   #8
rich weyand
rich weyand's Avatar
Just make sure to follow (or they follow) GM's crate engine break-in instructions. Here are the instructions for the 350/290 #12499529 engine. They're the same as for the #10067353 (which is the better choice between the two), and the break-in instructions begin in the middle of page 3.
https://www.chevrolet.com/content/da...e-12499529.pdf
The biggest things to note are:
1) no synth oil until 3000 miles.
2) The early oil and filter changes.
3) (Not in the instructions) The use of high-zinc (ZDDP) oil, break-in oil, or ZDDP oil additives. My own recommendation is a break-in additive in the first two loads of oil, and then use 1/2 bottle of ZDDPPlus per oil change. At 3000 miles, switch to Mobil1 10W30 with 1/2 bottle of ZDDPPlus per oil change.
Later these instructions say not to hook up the vacuum advance on the #12499529 engine, which is complete nonsense. Both engines should have a vacuum advance using the AR23/VC1853 vacuum advance can.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-07-2016, 07:12 AM   #9
Shady Rascal
Shady Rascal's Avatar
PCV and breather tube grommets for the valve covers.
Shady Rascal is offline   Reply With Quote
Old 03-07-2016, 07:43 AM   #10
Dead Parrot
New thermostat, new thermostat housing, might need an oil filter bypass, new hoses and belts, new exhaust donuts(if stock manifolds), new exhaust manifold studs, if the dealer can get the PROPER ones - a new temp sender and oil sender(if needed). Break in oil and a couple of gallons of new antifreeze. Might consider new motor mounts - easy to replace during the swap.
Some of this may be included in the dealer's price. Check before they start.
Have your flex plate examined. Easy to replace while swapping motors. PITA to replace later. Ask if the dealer knows how to properly shim starters. If they don't, expect to be replacing starters and flex plates. Consider getting a new starter. Easy to put on and properly shim while the engine is on the stand. Much harder when on the truck.
Dead Parrot is offline   Reply With Quote
Old 03-07-2016, 01:27 PM   #11
slotard
That's not a bad price at all for a dealer. Hopefully they do it right.
I agree that it's worth the $500 extra to have 290hp rather than 195hp.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 03-07-2016, 01:44 PM   #12
68c10owner
68c10owner's Avatar
You do realize that those 2 engines are exactly the same with the exception of the camshaft, right? $500 extra for a 40yr old grind that you can get onli e for under $100 not to mention being way too big for the heads and compression. Best bet is to buy the lower hp engine and add a cam more suited to the heads and compression
Anthony
Old 03-07-2016, 01:53 PM   #13
ptc
ptc's Avatar
Better thing to do is buy something worth spending the cash on..... SBC 427 600+ hp
I rode in the car (69 Camaro) it was in and it is an amazing engine!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-07-2016, 02:09 PM   #14
68c10owner
68c10owner's Avatar
This will lite your fire and this guy will probably install it for ya too! I rode in the car (69 Camaro) it was in and it is an amazing engine!
Yeah, thats practical for a guy buying a stock 350
Anthony
Old 03-08-2016, 02:40 PM   #15
gramps77
yeah, what he said. LOL
gramps77 is offline   Reply With Quote
Old 03-08-2016, 03:40 PM   #16
silvereagle07
silvereagle07's Avatar
That's a nice little engine. I had one in my 85 with an RV style cam. The only issue I ever had was when the pickup strainer came off in the pan. Easy fix. Nothing hurt. Caught it in time. Good luck man.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
