Disc brake help
Ok so I did a rear disc conversion on my 78 k20. Everything fit very tight and the upper caliper slide pin on the passengers side is ever so slightly rubbing the rotor at one point in the rotation. Its probably less than a quarter of an inch where it just barely brushes against the pin. I have tried everything to fix it, even took the rotor off and re-pressed it on.
Question is this a big deal or am I freaking out about nothing? |
| Bookmarks |
