![]() Join Date: Aug 2014
1972 chevy LS-1 swap
I am currently doing a frame off 1972 chevy 4x4 blazer and installing a LS-1 engine and need to find out if anyone has done this and can you help with the exhaust manifolds?
Re: 1972 chevy LS-1 swap
Corvette manifolds I believe stay tighter to the engine. I've always just made headers to work
1972 Dark blue, Cst, Highlander |
do you make and sell?
I think the tbss manifolds work. And I gonna watch your progress I'm going to be doing the same thing. What did you use for the cross member?
For Trans used the stock one and for the motor used the Pacific fab cross member!
What are the TBSS?
Trail blazer super sport
what year?
I have pacesetter long tube headers for a TBSS and they hit my shackles so I have to have them modified. I think Doug Thorley makes a conversion header.
![]() Join Date: Mar 2004
There's some 4x4 swap guys out there. I was going to use the TBSS manifolds on mine but put headers on instead. I'll sell them if you need them. You also need a special engine cross member unless you plan on fabbing one yourself. I got mine from Pacific Fabrication.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
that is where I got mine from!
GMC you have some headers for sale? For this application?
#13 |
I have the TBSS factory manifolds. I ended up buying Doug Thorley headears. They were like 6 or 7 hundred bucks, I forget.
#14 |
Thxs!
#15 |
I do, but I need the truck, each set I build are one off to fit a particular request or requirement
#16 |
Collector of Projects
2010 + Camaro manifolds tuck tight to the block and are 2.5" at the collector.
Check out this thread and the LSx section in general.... http://67-72chevytrucks.com/vboard/s...amaro+manifold |
#17 |
GMC. Which Tri-Y'S did you buy?
#18 |
I used 2012 Camaro manifolds. They fit like a glove.
#19 |
![]() Join Date: Jul 2007
Let me know if you're interested.
#20 |
![]() Join Date: May 2011
subscribed
#21 |
![]() Join Date: May 2005
TBSS work good
#22 |
Boosted Member
I used TBSS manifolds, cut the flanges off, and welded some pipe to them to extend down under the truck, to V-bands
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#23 |
heading to body shop!!!
#24 |
I bought the 323Y-C. http://www.summitracing.com/parts/dte-323y-c
I was able to use this shift linkage without any issues with them. http://www.summitracing.com/parts/lo...FQsPaQodg34Oyg
#25 |
trying to make up my mind on color ?
Any suggestions? |
