Old 03-06-2016, 10:27 PM   #1
clemsonteg
Cleaning up my garage sale
PRICES REDUCED! I NEED THIS STUFF GONE SO I CAN BUY MORE PARTS
Cleaned up my garage today and I found a few more parts to sell that I'm not using in my LS swap
Gauge cluster - $old
Sunpro Super TachII - $old
Sanden 508 Ac compressor - $130 shipped
PATC cable speedo 28% increase adapter. Worked great for correcting my speedo where the PO installed 3.07 gears in place of 3.73 gears - $old
100 amp internally regulated alternator - $60 shipped
clemsonteg is offline   Reply With Quote
Old 03-07-2016, 09:14 PM   #2
clemsonteg
Re: Cleaning up my garage sale
Bump
Old 03-09-2016, 10:50 AM   #3
clemsonteg
Open to offers also
Old 03-11-2016, 10:57 PM   #4
swamp rat
swamp rat's Avatar
How about 25 shipped on the speedo adapter?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-12-2016, 09:51 AM   #5
clemsonteg
I appreciate the offer. I paid $90 for it, so I think my price is fair.
Old 03-13-2016, 11:06 AM   #6
clemsonteg
Bump
Old 03-15-2016, 09:08 AM   #7
clemsonteg
Ttt
Old 03-19-2016, 08:43 AM   #8
clemsonteg
Prices reduced
Old 03-19-2016, 08:49 AM   #9
RickDeVon
RickDeVon's Avatar
May be in line for the speed adaptor ....need to know if it works also 3.42 and the hookup...just looking for info before I buy...thanks...
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline   Reply With Quote
Old 03-19-2016, 09:12 AM   #10
clemsonteg
There's no line. It's yours if you want it.
Old 03-19-2016, 06:05 PM   #11
rayray767
Was it leaking when you took it off?
rayray767 is offline   Reply With Quote
Old 03-19-2016, 08:06 PM   #12
clemsonteg
There's nothing to leak. It's just of gears on the inside with male and female threads to go between the trans and speedo cable. It's dirty from my hands and being under a truck for the last 3 years. It came from my working vehicle. Only reason it came out is because I'm LS swapping my truck and using Dakota Digital gauges which means no mechanical speedo
Old 03-19-2016, 08:52 PM   #13
RickDeVon
RickDeVon's Avatar
Will it work with a 3.42 gear set...
Old 03-19-2016, 09:17 PM   #14
rayray767
Really ? That's weird because mines leaking oil..I had did some research on this and came across Greg72 post looks like this part number my fix my problem.
Hopefully
Old 03-19-2016, 10:33 PM   #15
clemsonteg
Hopefully
This is an adaptor. It is certainly possible that your speedo gear housing is leaking, but that is separate from this piece.
Old 03-19-2016, 10:37 PM   #16
clemsonteg
It will work in the sense that it will fit your trans. Without knowing what gears you had or what kind of change you took on/how hour speedo reads now, I wouldn't be able to comment if it will work. My speedo was off on the low side. I needed it to read faster by over 25%.
Old 03-20-2016, 01:09 PM   #17
rayray767
Yep separate piece I thank you for all your info
Old 03-21-2016, 09:47 PM   #18
clemsonteg
Glad I could help.
Old 03-28-2016, 09:08 AM   #19
clemsonteg
i need this stuff gone
Old 03-28-2016, 04:04 PM   #20
lsjrl07
lsjrl07's Avatar
I will take the Tach if in Good Working Condition.
Gauge cluster - $80 shipped
Sunpro Super TachII - $25 shipped
PATC cable speedo 28% increase adapter. Worked great for correcting my speedo where the PO installed 3.07 gears in place of 3.73 gears - $35 shipped
lsjrl07 is offline   Reply With Quote
Old 03-28-2016, 04:36 PM   #21
clemsonteg
Worked when I took it out. I'm not using it or my old gauges with my swap since I bought a set of Dakota Digital gauges. Paypal is clemsonteg@yahoo.com
Old 03-28-2016, 04:54 PM   #22
lsjrl07
lsjrl07's Avatar
Money sent for Tach.
Old 03-29-2016, 08:54 AM   #23
clemsonteg
I got it. Ill get it boxed up and shipped out.
Old 03-30-2016, 08:12 PM   #24
clemsonteg
Bump
Old 03-31-2016, 04:39 PM   #25
RickDeVon
RickDeVon's Avatar
If the PATC cable is still for sale PM me payment info...
