Old 03-07-2016, 03:05 PM   #1
Crazy Rusty
Crazy Rusty's Avatar
Question rear frame crossmember/panhard attachment
I noticed while I started my frame prep that the frame crossmember that has the panhard bar connection point on it is about 1 1/2" offset from where it attaches side to side (shorter on the pass side I think) (red lines). While the rear measurements are exactly the same (blue lines)
This seems to be from the factory as while the frame is slightly out of square (1/4 - 1/2"), the crossmembers are all still factory riveted. Does anyone know why this was done? At first I thought the frame was way off or something was bent but measuring from rivet to rivet shows a definite change.
Crazy Rusty is offline   Reply With Quote
Old 03-07-2016, 03:17 PM   #2
Rust-O-Matic
Rust-O-Matic's Avatar
Re: rear frame crossmember/panhard attachment
Unfortunately I don't have an answer to your specific question, but I can tell you it's not just your frame. My frame looks exactly the same as yours, and every frame for these trucks I have ever seen has the same skewed crossmember.
Rust-O-Matic is offline   Reply With Quote
Old 03-07-2016, 03:51 PM   #3
scoot_mcgrute
I've noticed that they are all that way. I think it might be angled for the panhard bar to be able to move up without hitting the cross member. My dad thinks it's angled for the tire carrier. Messes with my head every time I see it!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-07-2016, 03:54 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
As I understand it, it's angled for ladder type rigidity.
Old 03-07-2016, 04:14 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
GM angled this crossmember to prevent the frame from "racking" like a ladder frame would naturally want to do. This is an engineering design.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-07-2016, 04:50 PM   #6
Rust-O-Matic
I don't mean to question anyone's intelligence or start an argument, but the slight angle of that skewed crossmember does not look sufficient to have any real effect on the frame's potential for racking. Seems more like it's meant for clearance, or something along those lines.
I'm admittedly not an engineer, but I am an engineering technician, and have spent every day of the last 9 years drawing structural plans for the same firm. Diagonal bracing meant to resist racking in a rectangular frame is typically positioned at no less than 45 degrees.
Old 03-08-2016, 12:44 AM   #7
Captainfab
60-66 Nut
In my opinion the crossmember is angled for clearance with the panhard bar should it come up that far.
