Old 03-07-2016, 03:43 PM   #1
Mmorgan32
Mmorgan32's Avatar
Does anyone know where I can find this bolt?
It's my seat. The bolt that holds the back to the bottom. I've searched my parts catalogs and hardware stores, kragen don't even have it
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 03-07-2016, 03:48 PM   #2
Jose's 69
Re: Does anyone know where I can find this bolt?
Try McMaster-Carr. I just got some left hand threaded nuts through them that I could not find anywhere else. Their website is pretty easy to navigate, you just have to know the specs of the bolt.
Jose's 69 is offline   Reply With Quote
Old 03-07-2016, 03:49 PM   #3
Davidf
McMaster-Carr? Looks like it may be a 100 degree flat head machine screw/bolt:
http://www.mcmaster.com/#machine-screws/=11ft4uv
Find the correct size and cut to length, if necessary.
Davidf is offline   Reply With Quote
Old 03-07-2016, 03:53 PM   #4
Jose's 69
Its like a Grainger. They sell all kinds of supplies and hardware.
Old 03-07-2016, 04:00 PM   #5
68Gold/white
A hardware specialty place might help you. You'll likely have to spend some minimum amount of $$$ if they have it, be prepared to buy some other bolts, etc, if you find one...
68Gold/white is offline   Reply With Quote
Old 03-07-2016, 04:36 PM   #6
Mmorgan32
Mmorgan32's Avatar
Awesome thanks. I'll try that.
Old 03-07-2016, 04:50 PM   #7
dfwright
dfwright's Avatar
From the looks of the other one, there's a lock washer integrated with it? If you have a Fastenal nearby, it might be worth taking the other one out and taking down to the Fastenal to see if they have what you need.
I will state the disclaimer that the ones around here have disappointed me a time or two on what I thought should be a commonly available bolt.
You might also want to consider heading over to the parts board, and find DLTRUCK1973's hardware thread and ask if he has one. I've bought a bunch of bolts and other miscellaneous hardware from Tom.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 03-07-2016, 04:56 PM   #8
dazza
dazza's Avatar
not to be a smart-ass, but did you check under your seat? Places like that (garage floor etc) usually have them in stock for me, but I don't realize it until I've gone to great lengths to obtain a replacement!
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 03-07-2016, 04:58 PM   #9
Mmorgan32
Mmorgan32's Avatar
First place I looked lol. When I replaced the carpet I looked under the gas tank and under the sill plate covers too
Old 03-07-2016, 05:05 PM   #10
Gromit
I haven't done this yet; but it was on my list to put a knob-bolt in that location to make it easier to fold the seatback forward when I need access...
The bolt spec should probably at least a grade 5 though if not grade 8 for crash worthiness
Example photo attached - that is just the general idea - the one shown isn't necessarily the right threads or length..
Gromit is offline   Reply With Quote
Old 03-07-2016, 05:06 PM   #11
picklito
Pretty funny. Exactly what I was thinking.
picklito is offline   Reply With Quote
Old 03-07-2016, 05:20 PM   #12
NC_John
NC_John's Avatar
Here is the bolt. Good luck. I need one too but haven't been able to find a suitable replacement.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 03-07-2016, 05:32 PM   #13
El Dorado Jim
try True Value Hardware
El Dorado Jim is offline   Reply With Quote
Old 03-07-2016, 06:01 PM   #14
AlbertaClassic
I found some at a local AutoMart. I needed a couple and the guy gave me some for free. They did not have the lock washer on them and they ended up having a hex head. They threaded in perfect. The couple I got don't match the others, but hey, the upholstery goes over them anyways.
AlbertaClassic is offline   Reply With Quote
Old 03-07-2016, 06:13 PM   #15
AlbertaClassic
Old 03-07-2016, 06:25 PM   #16
Davidf
With this picture of the bolt, it looks like a standard flat head Phillips machine screw/bolt, not the 100 degree version. Probably 3/8x16
Old 03-07-2016, 06:32 PM   #17
toolboxchev
Try Tom @ DLTruck on this site, he has bins of nuts and bolts.
toolboxchev is offline   Reply With Quote
Old 03-07-2016, 07:03 PM   #18
jamie72
jamie72's Avatar
junk yard?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 03-07-2016, 07:38 PM   #19
Chknlyps2
I just checked a 68 GMC I have and both sides have been replaced with 3/8" hex head bolt (9/16" head).
As others have posted a flat head allen cap screw can be found pretty easy at good hardware stores.
Not sure if this is the right length
https://www.fastenal.com/products/de...%20Screws%22|~
Chknlyps2 is offline   Reply With Quote
Old 03-07-2016, 08:20 PM   #20
Mmorgan32
Mmorgan32's Avatar
Ya that's probably what I'll do then. I was trying to find the right one but I'm getting a new seat cover anyways so it won't matter cause it'll be covered up
Old 03-07-2016, 08:38 PM   #21
Procurement_man
Procurement_man's Avatar
I found them a ACE hardware, it has an Allen head instead of Phillips but works great.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 03-07-2016, 11:46 PM   #22
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
http://www.mscdirect.com/browse/tn/F...593+4287782570
MSC has all kinds of bolts and fast shipping. I don't remember what size they are but the link should get you close.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
72 GMC Suburban 1500 Super Custom. White/Med Olive/White, Parchment interior.
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
78 AM General M35A2C with winch, multifuel with C turbo, bobbed deuce on 47” tires.
dutchmanz is offline   Reply With Quote
Old 03-08-2016, 07:25 AM   #23
Grumpy old man
Grumpy old man's Avatar
Ace hardware
Grumpy old man is offline   Reply With Quote
