Old 03-07-2016, 06:29 PM   #1
Claudman
Ranch Truck 67 C10 Short Wheelbase Big Window
This is my 1st post and I wanted to introduce myself and my new truck, a 67 C10 Short wheelbase with big window. Following are some pictures
Interesting option was the speed warning (which still works).
The PO's (there were three in total) made some good changes and maybe not so good changes.
The original truck had a chrome bumper and Side Trim Molding, which you can see are gone. The holes for the trim molding are sealed with body filler. I haven't decided if this is good or bad. I like the look without molding, but I also like the stock look.
The original engine and transmission are both gone replaced by a crate 350 with vortex heads (170-180 compression in all cylinders) and an 700R4 transmission. Motor seems to be in great shape, runs well, and only seems to have an issue with a little oil smoke on startup. I'm guessing the valve seals, but since this is my first Chevy since 1978, I'm starting with very little experience. Transmission is not so good and I am still working to figure out if the TV cable is set properly or if the transmission is shot. Seems to slip between 1st and 2nd under full throttle. I have replaced the carb bracket and the TV cable and adjusted per what I can find on the internet, but it still acts up, so I'm guessing the transmission needs work. Anyway, it's great that I have an automatic overdrive in the truck and that the drive shaft was replaced with a one piece drive shaft.
Suspension and steering are all a hand full now. I have been driving a Acura RDX as my daily and also have a 72 Datsun 510 wagon which is highly modified with motor and suspension changes. Both these rides handle like go carts compared to the C10. Yeah, I know its a truck, but driving this thing (no front swaybar, no power steering, no power brakes, 4 wheel drums) really makes me wonder why it is still in one piece.
Well, no worries since I have already got a Ridetech coilover suspension package, power steering conversion, 4 wheel disc brakes with power booster, 5 lug rear axles and front sway bar on order.
The cab is generally rust free. The truck spent it's life in the hill country of Texas which is mostly very dry. The drip rails on both sides seem to have some rust bubbles and a little rust in the door corners on the outside. Rocker panels look OK at this point, but I wonder what it looks like on the inside. Anyway, at this point the paint is OK for now.
My biggest issue now is selection of wheels and tires. I would like to keep all the wheels and tires the same size if possible, but would like any suggestions on wheel size and backspacing you might have. I want at least an 18" wheel, but am willing to consider 20" wheels, but am a little worried about bending a rim since I do plan on driving it and don't want to worry about bending an expensive rim.
Once I have all the parts I plan on pulling the bed off to install all the Ridetech parts, fixing the bed and putting it back together. Any suggestions on wheels and tire would be appreciated.
Thanks for looking,
Claudman is offline   Reply With Quote
Old 03-07-2016, 06:35 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Ranch Truck 67 C10 Short Wheelbase Big Window
I'd drive it "as is" but I'm an old fart.
nice looking truck
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-07-2016, 07:34 PM   #3
Adam Moyers
Congratulations on a great truck. One day I will find one like that to make my own. The search continues.
Adam Moyers is offline   Reply With Quote
Old 03-07-2016, 07:39 PM   #4
ho70
ho70's Avatar
Hubcaps are all that truck needs, nice!!
ho70 is offline   Reply With Quote
Old 03-07-2016, 07:43 PM   #5
swamp rat
swamp rat's Avatar
Looks like a great truck to start with! Keep an eye on the bubbles in the drip rail and try and get them fixed asap.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-07-2016, 11:03 PM   #6
89AKurt
89AKurt's Avatar
Originally Posted by Claudman View Post
... Yeah, I know its a truck, but driving this thing (no front swaybar, no power steering, no power brakes, 4 wheel drums) really makes me wonder why it is still in one piece.
Welcome!
Had to laugh. My daily driver is a MINI Cooper S JCW. I'm a Gemini, so I am able to switch from radar-detector-required, to laid-back-cruise don't be in a hurry and leave 10 car lengths distance.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-07-2016, 11:53 PM   #7
68bowtie
68bowtie's Avatar
beautiful truck!! reminds me of this 67 bbw i tried to buy a while back. i vote for 67-68 hub caps also...
Old 03-08-2016, 08:35 AM   #8
jmader
jmader's Avatar
Really cool truck! Welcome to the forum
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 03-08-2016, 09:07 AM   #9
68panelman
68panelman's Avatar
Beautiful truck, welcome to the board
68panelman is offline   Reply With Quote
