Old 03-07-2016, 10:56 PM   #1
Chevy3+3
Need hydrualic plumbing ideas from M12x1.0 to ???
Since I am dong my 5 speed swap I need to get the clutch line plumbed. I have decided to go with a SS braided PTFE line between the clutch MC and slave cylinder. I am trying to get from a M12x1.0 connection at the clutch MC to a -AN3 style male in as short of a distance as possible. If I could get an adapter from M12x1.0 male to M10x1.0 female that would be great (because nobody makes a M12x1.0 to -AN3 adapter but I can get a M10x1.0 male to a male -AN3 fitting).
Here is my problem....I need to find an adapter fitting that screws into the clutch MC that seals correctly. The stock line would screw into the clutch MC using the M12x1.0 end fitting.
What style end (without a line in it) will screw into the clutch MC and properly seal? Is it possible to use a M12x1.0 bubble end or do I want an inverted flare end?
I would like to get from the female M12x1.0 in the clutch MC to a M10x1.0 female. If I can't get that then I could make do with a M12x1.0 to 1/8NPT female.
Any thoughts?
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 03-08-2016, 01:55 PM   #2
kdh454
Re: Need hydrualic plumbing ideas from M12x1.0 to ???
Is this what you are looking for?
http://ormebrothers.com/products/met...pter-dual-seat
kdh454 is offline   Reply With Quote
Old 03-08-2016, 01:58 PM   #3
Chevy3+3
Originally Posted by kdh454 View Post
I already tracked down that piece but I need to adapt from the male M10x1.0 on that fitting to the M12x1.0 needed to screw into the clutch MC
Old 03-08-2016, 02:37 PM   #4
kdh454
Why not buy the -3AN to M12x1.0 fitting listed? Maybe I'm missing something?
Old 03-08-2016, 02:53 PM   #5
Chevy3+3
Ah heck I didn't see it when I looked through the listing. That should work. You'd be amazed how many places I have called and websites I've searched and that option has not been available. Thanks!
