![]() Join Date: Apr 2013
rear airbags..
whats up brothers....im wanting to bag my 82.. I don't want to lay frame or lose my original bed floor.. just a simple bag job where I lay crossmember and on my small notches...ive heard of folks using helper bags for this on the rear.. is this doable.. any help or advice will be much appreciated
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
It followed me home?
Re: rear airbags..
if you cant weld, ridetech AOL is cheap and a great way to go.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: rear airbags..
Take a look at http://www.ridetech.com/store/trucks...hash=V260.V328 the rear kit will get you as low as you can get with out cutting the bed.
Member of the longbed union.
Re: rear airbags..
Are you wanting to keep the leaf springs?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Frequent Flyer
Re: rear airbags..
As mentioned above the ridetech kits are very nice parts. I've helped install them on a couple of trucks & wouldn't hesitate going that route either if it worked in your application.
I decided designed my own kit that worked out with the set up I had. I got a set of link bars from Ekstensive, I put an adjustable heimed panhard bar in front of the rear end since I didnt have room behind due to the K5 gas tank, I used shocks in the factory locations & a bolt in Western Chassis notch that we actually had to make smaller because the rearend would hit the bed floor before it bottomed out in the notch. Laid out the top of my rearend is 1/4-1/2" from hitting the bed floor. We welded a plate inside the notch to make it smaller, then tapped & threaded the hole so that i could easily adjust the bump stop to prevent it from hitting & also to get the right rake. My front has the factory inner fenders in place as well. Last edited by JWall; 03-08-2016 at 08:45 AM. |
Re: rear airbags..
that's great work brother.. I might go that route...thx for the info guys
driving is in my blood
Re: rear airbags..
Pull all but the main leaf and add a helper bag setup. Tada, cheap mans rear bags.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
