03-08-2016, 04:52 PM | #1 |
New 68 Stepper Build...IM BACK!!
after the long and agonizing departure of the stepper i built, i have decided to start another one! Same concept, but totally different this time around....I am looking for an A/C cab as this one is trash. Can someone please help me find one?
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
03-08-2016, 05:10 PM | #2 |
Re: New 68 Stepper Build...IM BACK!!
Only pic i have right now...until i pick it up and finish paying for her....
03-26-2016, 10:07 AM | #3 |
Went and picked her up last nite. Got a lot of parts that I will be selling to help fund and recover. One is a ford 9" I won't be using.
12-25-2021, 01:18 PM | #4 |
i have officially starting building the truck. Should be funner this time around.
So far.... ENGINE 2000 LQ4 .030 over Diamond pistons mahle bearings compstar rods balanced & polished stock crank f body pan 243 ls6 heads ls7 coils with factory harness rebuilt comp 54-444-11 cam comp 850-16 lifters comp 3158KT adj. timing set comp 13702 trunion kit comp 26925TS dual spring kit ARP studded top and bottom HV modded oil pump holley 300-132 intake holley sniper efi 550-510d TSP hidden valve covers holley air filter and cover to match speed engineering long tube headers msd 60143 ignition control no accessory drive chosen yet.... TRANSMISSION 1997 Camaro T56 DONOR (traded some old psi washing equipment) after tearing into it and finding more damage than i expected from a 85k donor, had to weigh options on purchasing a new magnum or finding another t56 but for ls. with the new magnum being almost 5k, no luck on finding a ls t56, and tick performance telling me to "just buy a new magnum" i decided to just convert and build this as a stage 2 t56. NEW LS input shaft - REM finished NEW TREMEC Mid Plate NEW TIMKIN bearings shipped from FRANCE. Weird, no one here in the states had ALL timkin. NEW Complete syncro assemblies 1/2, 3/4, 5/6, and Reverse (will be doing the REVERSE syncro/shift fork mod for full engagement) Billet Keys 1/2, 3/4 Bronze Pads 1/2, 3/4 Steel 3/4 shift fork New rings and retainers NEW REM finished Countershaft NEW REM finished 5/6 driven gears NEW REM finished Rev driven gears CLUTCH ALL McLeod setup for the .4 truck crank ALL AND ALL Im 2k invested in just the t56. should hold up pretty well now. REAR end 1968 GM 12 bolt MOSER axles MOSER studs Detroit TRUeTRAC KOYO axle and Carrier bearings, National for Pinion MOSER diff cover with carrier lock RICHMOND 4.10 Gears FRAME AND SUSPENSION Stock GM 1968 frame QA1 Front and rear sway bars QA1 Full tubular Coilover conversion in front Wilwood Pro spindles Performance online rack and pinion Wilwood 6 piston in front plain slotted rotors wilwood 4 piston with e brake in rear plain rotors HPI frame brace QA1 Full rear coilover conversion with tubular trailing arms tanks inc fuel tank and fuel pump
12-25-2021, 01:29 PM | #5 |
Looks like a good plan. Looking forward to seeing what you do with this one.
12-25-2021, 01:30 PM | #6 |
I’m trying to upload pics. looks like i have to upload one at a time.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 12-25-2021 at 01:50 PM. |
12-25-2021, 01:53 PM | #7 |
more
12-25-2021, 01:58 PM | #8 |
these are way out of order. ill be better from here on out
12-25-2021, 03:35 PM | #9 |
Pictures are good, in or out of order. And yeah, if you are posting from a phone, ur linited to 1 at a time, especially if they are large size.
12-26-2021, 10:16 AM | #10 |
Quite the project, bravo !
01-06-2022, 12:46 AM | #11 |
Almost done with the T56. Everything inside is new and stage 2. All new gears, synchros, everything except main shaft and countershaft extension. Did the SST forward shifter relocation as well.
Posted via Mobile Device Last edited by 77chris03; 01-06-2022 at 12:57 AM. |
01-06-2022, 12:50 AM | #12 | |
Posted via Mobile Device |
01-06-2022, 12:53 AM | #13 |
01-06-2022, 11:52 PM | #14 |
Picked up a set of buddy buckets with the frame and all. Very nice piece. Should go good with the set up. Saw it pop up on FB Marketplace and picked it up a few hours later. $1500 bucks seemed like a good deal to me!
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 01-07-2022 at 12:02 AM. |
01-07-2022, 12:04 AM | #15 |
Doing a very similar build as yours with my 71 stepper. I am going ls3 and t56 magnum. Are you doing anything with the c clip in the rear? Eliminators? Or feel safe with the moser axles?
01-07-2022, 12:10 AM | #16 | |
Went with the Eaton TruTrac Posi.
01-07-2022, 12:13 AM | #17 |
I have the truetrac to put in also. Love them. I didn’t think my brake kit would allow it either. Just thought I’d ask. Thanks
01-07-2022, 12:20 AM | #18 | |
My t56 is 99% done. full build. Even did the shifter relocation. YES..the rear end is in my living room....sitting right in front of the tailgate bench i made from my step side when i tore it down.
01-07-2022, 01:37 AM | #19 | |
I was wondering about 4:10 gears. It has 3.73. I was thinking I could finish and drive it before I do the rear and if it needs more go 4:10 Using a bench seat? I think I might need the shifter relocater also |
01-07-2022, 01:49 AM | #20 | |
https://www.tremec.com/calculadora.php 1 2 3 4 5 6 GM T56 (`94 and up) 6-speed manual 2.66 1.78 1.30 1.00 0.74 0.5 Select Transmission : Magnum-F 2.66 - .50 Engine RPM : 2500 Enter your desired RPM for racing or cruising here. Axle Ratio : 4.10 Enter your rear axle ratio here. Tire Height (in) : 30 Enter your tire height here. Use the Aspect Ratio calculator below if you do not know your tire height. Ratio MPH 1st Gear 2.66 20.46 The estimated speed you will be traveling based on the parameters you established and the transmission you selected. 2nd Gear 1.78 30.57 3rd Gear 1.30 41.86 4th Gear 1.00 54.42 5th Gear .74 73.54 6th Gear .50 108.84
01-07-2022, 01:55 AM | #21 | |
Once i get the rear end and QZ1 stuff on, Ill mock up the bed parts and figure something out. THeres is like NO INFO on stepsides with the short rear end.... I got the SST shifter relocator...If you do it yourself...be sure to grind the surface hardening before you drill... I promise you will break ALL of your bits.. I have access to a machine shop right down the road and he didnt believe me when i said its surface hardened....3 end mills later.. i grabbed it off the press and ground it down on both sides...voila...straight thru. Everything else can be done with a metabo blade made to cut stainless...
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 01-07-2022 at 02:01 AM. |
01-07-2022, 07:19 PM | #22 | |
Just for reference... your C clips being caged, billet capped, fat snap ring etc is not going to help vs C clip eliminators. C clips falling out or breaking isn't really the problem. Axle shafts breaking is the problem. If a C clipped axle breaks, the splined tip of the axle with the C clip on it almost always stays right where it was, inside the differential. At this point on a drum brake car the rest of the broken axle slides right out of the housing. I personally believe with most disc brake rear end setups C clip eliminators are outdated/unnecessary. The brake caliper bracket is usually bolted right to the axle flange, and has the brake rotor captured. This effectively traps the axle and prevents it from coming out of the housing even if the C clip end breaks off. Sorry for the book, just one guys opinion on the subject. |
01-07-2022, 07:21 PM | #23 |
PS nice build you've got going
01-08-2022, 12:43 AM | #24 | |
01-08-2022, 03:27 AM | #25 | |
Tags |
slick67 |
