Old 03-08-2016, 06:30 PM   #1
screech
screech's Avatar
DBC 5.3 swap--gas pedal solutions?
What is everyone doing for gas pedals on their drive by cable set ups??
1966 C10 Stepside LS 5.3 on air (almost)
Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=669050
screech is offline   Reply With Quote
Old 03-08-2016, 08:31 PM   #2
JMac11
JMac11's Avatar
Re: DBC 5.3 swap--gas pedal solutions?
Stock pedal worked great in my 1972, put in the cable for 2000 truck
JMac11 is offline   Reply With Quote
Old 03-08-2016, 08:36 PM   #3
screech
screech's Avatar
The earlier trucks used a linkage style and I don't think there is any way to make that work. Possibly swap out a little older one like you have.
Build:
Old 03-08-2016, 09:52 PM   #4
clemsonteg
These might help they might be 67-72 specific but it may give you an idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=371099
http://67-72chevytrucks.com/vboard/s...00#post1383300
clemsonteg is offline   Reply With Quote
Old 03-08-2016, 10:07 PM   #5
qwik
qwik's Avatar
I got this pedal out of a 2007 v6 truck, it seemed like it would've worked fine. After sitting the motor in place I've decided to stay with my stock linkage (68) and use the lokar s-1034.
qwik is offline   Reply With Quote
Old 03-08-2016, 10:12 PM   #6
Robznob11
Robznob11's Avatar
Well I used the pedal and cable out of tthe doner truck. Cut the piviot point out and weld a little plate to bolt to the floor. Heat and bend with a torch as needed. However I just picked up an chrome adjustable pedal off eBay for 30 bucks. Looks just like the locar style. Nice piece I think anyone could make work easy. Search chrome gas pedal or hot rod accelerator pedal. You should find them. They even have the spoon style if that's what you like.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-10-2016, 10:22 PM   #7
qwik
qwik's Avatar
Mine went smooth and works good with the stock foot feed.
Old 03-10-2016, 10:29 PM   #8
qwik
qwik's Avatar
Not sure why the pix are rotated.
Old 03-10-2016, 11:22 PM   #9
Robznob11
Robznob11's Avatar
Here's a pic of the 30$ eBay pedal. Also the cable off any v6/v8 truck works perfectly nice and long. Of chores the pedal is 100% adjustable with set screw and splines.
LED TAILS
Old 03-12-2016, 01:08 AM   #10
62chevy302
hillbilly
62chevy302's Avatar
Im interested in this also. Is there a factory setup that will work?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 04-15-2016, 10:16 AM   #11
screech
screech's Avatar
So I went with the cheap lokar style pedal. Now I'm having a hard time sourcing a throttle cable that will mount thru the firewall to the pedal and work for my dbc throttle body.
Any advise?!
Build:
Old 04-15-2016, 11:06 AM   #12
Matt Cramer
I used my stock '72 Chevy pedal and a mountain bike brake cable. I suspect it wouldn't be that much work to put one in an earlier cab.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-15-2016, 11:23 AM   #13
suburban99
suburban99's Avatar
I used a 90's Nissan truck cable pedal with stock cable. Cut cable to fit and installed a bicycle cable repair end on it.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
