Old 03-08-2016, 07:09 PM   #1
Johnepp18
70 C30 Brake upgrade
I'm looking into upgrading the front brakes from drum to disc. Anyone know of any ideas or kits that might work?
Johnepp18 is offline   Reply With Quote
Old 03-08-2016, 07:13 PM   #2
hugger6933
Re: 70 C30 Brake upgrade
Use the disc from the 73 to 87 just as the C-10 guys do the action is the same just bigger and lots heavier. You also could do the 71-2 swap but you have a much better change finding the 73-87 more coverage that way. Good luck. Jim
hugger6933 is offline   Reply With Quote
Old 03-08-2016, 07:19 PM   #3
SS Tim
SS Tim's Avatar
Square body factory parts are the way to go.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Hopefully you have a brake booster now (J70), but if not then that or a Hydroboost would be a great addition as well.
SS Tim is offline   Reply With Quote
Old 03-08-2016, 07:19 PM   #4
kwmech
Exactly ^^^. I did my 69 flatbed last summer, I kept the upper and lower control arms. Sourced the rest from a 77...... spindle out.... along with the steering links. It all bolted right up. I did have to have rubber brake hoses made b'cuz of the different fittings on the frame. Rotors were/are thicker than the 71-72 style
Old 03-08-2016, 07:35 PM   #5
Johnepp18
It's a factory power brakes so I figure I'll need an new proportioning valve. I'm trying to find a 73-87 one ton to use as a donor.
Old 03-08-2016, 07:57 PM   #6
Steve-W
Steve-W's Avatar
I swapped the complete crossmember of a 73 2wd blazer. Had my share of problems, but now the brakes are where I want them to be
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 03-09-2016, 12:14 AM   #7
old Chevy guy
old Chevy guy's Avatar
Just did this swap from 78 C30 onto my 71 C 20 .work great, like its made for it. Having a hard time finding new dust/backing plates though. Old one's from the donor were pretty rusty.
old Chevy guy is offline   Reply With Quote
Old 03-09-2016, 12:38 AM   #8
71swb4x4
71swb4x4's Avatar
I used a 1975 c30 for my 1967 c30. It was a hydro boost system, works extremely well.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-09-2016, 10:56 AM   #9
70's luvr
I just bolted this up from a 1980 C30. Used a 1972 c30 brake booster,master cyl with correct bracket. Proportioning valve was from a 1985 k5 blazer.
70's luvr is offline   Reply With Quote
Old 03-09-2016, 12:32 PM   #10
kehstr
kehstr's Avatar
I would say add hydroboost, it's not that much work, and the brakes work SO MUCH BETTER than vacuum brakes
kehstr is offline   Reply With Quote
Old 03-09-2016, 04:33 PM   #11
mike16
this sumerizes it in a nut shell. X2
mike16 is offline   Reply With Quote
Old 03-09-2016, 08:19 PM   #12
Johnepp18
Thank y'all a lot for the tips. Now I have to find a donor somewhere around my area.
Old 03-10-2016, 12:39 AM   #13
old Chevy guy
FYI the new rotors for the 73-87 spindles that take your bud wheels are still available from auto zone. around $94 plus tax each ,part#55025
