03-09-2016, 01:18 AM | #1 |
Upper Clutch Linkage
Hey guys, I am need of the clutch linkage that goes between the clutch pedal and the bell crank, my original looks was reinforced with some welded on flat bar at some point and the end of the rod into the bell crank is getting worn relatively thin. What is out there for replacements? LMC has a kit with both linkages that have some heim joint things on the ends, that looks appealing for smooth operation instead of steel on steel, has anyone tried one?
03-09-2016, 10:07 AM | #2 | |
The Older Generation
Re: Upper Clutch Linkage
You might try the parts boards. There are quite a few guys parting trucks out. You can't post a wanted to buy unless your name is in Blue (Premium Member) but if someone has one for sale you can buy it. Check all of the parts boards because the clutch rod should be the same except for maybe 4x4's.... LockDoc
03-09-2016, 02:46 PM | #3 | |
Still works great. I did have an issue when one of the arms of the Z-Bar broke off, but that can happen to any 40+ year old metal structure in daily use. For what LMC wants for their Heim joint rods, I think you could fabricate a couple of clutch rods yourself, with a machinist.
03-09-2016, 02:47 PM | #4 | |
03-09-2016, 08:17 PM | #5 |
Yep, forgot about that.... Thanks.
LockDoc
03-10-2016, 01:49 AM | #6 |
I would go for the one from LMC with the heim joints
03-17-2016, 09:30 PM | #7 |
Have you tried them Jim?
Did you notice a difference in pedal pressure vs. stock sunshine? |
03-17-2016, 10:07 PM | #8 |
I built my own with heim joints. Now both the upper and lower links are adjustable, all the wear and slop is gone, and the motion is way smoother. Took a Saturday and about $50 for joints, tube ends, and some DOM tube.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-18-2016, 12:13 PM | #9 |
Is the upper rod strait from the factory? Mine looks like it has some curve to it but it might have been bent before it was reinforced. Lmc says theirs is only compatible with exhaust manifolds but I don't see any way they would interfere with headers, maybe heat being closer is the issue?
03-18-2016, 02:26 PM | #10 | |
I had already had to modify the z-bar to work with my headers, so a straight rod from the pedal attachment worked perfect for me.
03-18-2016, 10:46 PM | #11 |
Mine definatly has some curve to it, the lmc one looks totally strait, I wonder how that works. Has anyone tried their kit?
03-19-2016, 12:02 AM | #12 | |
I would bet LMC is reselling the kit from here: http://cmc.speeddirect.com/itemdesc....%2D125&eq=&Tp= I basically copied that and just made my own for less than half
03-19-2016, 12:12 AM | #13 | |
03-19-2016, 09:20 AM | #14 |
That has been my experience also.
03-22-2016, 05:42 PM | #15 |
I called speed direct, they do make the kit lmc sells. Their engineer said it would only work with strait rods, which mine clearly isn't. Those that made your own did your upper rod have a link in it like this? He thought the curved linkage meant it was a 4wd which my truck is not any thoughts on an alternative?
03-22-2016, 11:16 PM | #16 | |
PIX:
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-22-2016 at 11:46 PM. |
03-23-2016, 12:47 AM | #17 |
Thanks Sunshine, that's just the explanation I was looking for!
03-23-2016, 10:17 AM | #18 |
Did yours have the "strait" or curved upper rod? The kit will only replace a strait rod. Im tempted to retrofit curved joints onto my curved rod.
03-23-2016, 11:51 AM | #19 |
My truck had the straight rod because it was originally an L-6. My small block sits in the L-6 rearward position. I did have to modify the z-bar when I put the headers on it to clear, the ear for the upper clutch rod to attach had to move away from the engine.
the linkage I made is just straight DOM tubing sourced on eBay with 3/8" teflon heim joints and matching tube ends I got from either Jegs or Summit. I think I have $50 in the whole setup. I used a reverse threaded piece in the upper clutch rod so I can just turn the rod to set the pedal height. Took a Saturday to cut everything to length and weld it all up. I made a new bottom link as well. This is one of my favorite modifications I had done to the truck. The clutch is so much smoother now without the slop in the linkage.
03-23-2016, 11:52 AM | #20 |
I have no clue why the posting turned 2 of the photos sideways....
03-25-2016, 12:15 PM | #21 |
That's slick. Is a rubber boot on there like that how they came? Mine clearly has been monkeyed with.
03-25-2016, 12:28 PM | #22 |
Yes, thats a stock reproduction boot.
04-09-2016, 11:23 PM | #23 |
What if I were to add heim joints to my current 'dogleg' rod? Would the kink in it somehow put odd stress on the joints?
04-09-2016, 11:30 PM | #24 |
It would be fine.
04-25-2016, 12:34 AM | #25 |
I think I'm going to modify my current rod to take heim joints. I guess a shouldered bolt goes through where the rods poke into the cross bar? What size of hole do I need going through the joint?
