1972 3 speed shifter
so on my way to work this morning and went to pull the shifter into first / reverse gate and the pin broke off the end of the shifter luckily it was stuck in the 2/3 gate so I could continue on to work. Tried to search up a replacement do you guys know who sells replacements and or is the auto shifter the same as the 3 speed?? thanks in advance for the info.
Re: 1972 3 speed shifter
are you talking about this?
mike, im pretty sure its the end of the handle that broke stuck at work will tear apart after work and post a pic of what I find broke.
#4 | |
Always on the hunt...
![]() Join Date: Sep 2006
according to a catalog I have, a shift lever from an automatic will work, just hit a wrecking yard if you need to get your truck going right away
Wow that sucks! Glad you are OK and able to get it fixed (I assume and hope).
My dad had 2nd gear go out in this 3 speed car he had. He had a very steep hill to climb too with lots of hair pin curves.......he said he "had traffic backed up for miles climbing that hill in first gear." ![]() |
thanks Jim for the response I know were there is an auto column so I will have to pick it up
In the ten ring- six cylinder 3 on the tree and 4:11 gears starts out in second fine but there is one hill on the way home with a light at the top that was red on the way home a little sweating and little prayer I was able to time it so I didn't have to stop thankfully |
3 ott and 4.11 rear end? That's what my truck is!
I could see where that would be dicey! We must have pics of your truck! Righ here, right now, this thread. *We don't really need pics, I just want to see a truck with my exact set up. ![]() |
in the ten ring as soon as I figure ou how to post I will
In the ten ring im trying lets see if this works
There they showed up
Grandpa bought it new in 72 now has 330,000 miles on it and it dives like a dream just installed the 3 engine in it so glad he got mad at the 69 ford f100 for eating up front tires and traded it in on this truck doubt the ford would still be around today |
