03-09-2016, 04:19 PM | #1 |
1974 saddle vinyl interior color code
My dash pad and door panels need to be painted. I'm not doing it, the shop is. Their goof.
Before I let them pick/find the color I'm attempting it. I'm the one that's going to have to live with it! I know about SEM etc. They want to mix and spray, so I need to find the GM paint code for the saddle interior. Anyone have it or a good resource? I greatly appreciate any help. Thanks
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
03-09-2016, 06:59 PM | #2 |
Re: 1974 saddle vinyl interior color code
The saddle tan vinyl interior code on my 1984 is 62v. No clue if 1974 uses the same color codes.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-09-2016, 09:13 PM | #3 |
I have 74 gmc with saddle interior at home. I should be able to get it for you in the next couple days when I make it home. The spid and all is intact. I'll let ya know
-Cody |
03-09-2016, 09:49 PM | #4 |
My spid reads 674. I was under the a assumption that the 674 was just the option number? Am I incorrect? I hope I am. You know what happens when one assumes! Ha-ha
03-10-2016, 09:46 AM | #5 |
I'm not sure. You have me thinking now. I have never really looked up interior colours. I remember seeing a list of options on the inside of door panels. You might get a number off the inside of that or a similar interior panel. I'll take a look later. See what I can find
-Cody |
03-12-2016, 02:40 PM | #6 |
Mine also shows 674
-Cody |
03-12-2016, 02:46 PM | #7 |
These are the numbers I meant inside door panel. It shows green, sand, saddle, ox,and grey in the far right column and the 3 columns to the left show standard, delux, and Cheyenne With a list under each. I think they are part numbers
-Cody |
03-12-2016, 03:52 PM | #8 |
I think that's what shows on my back of my panels also. I gotta find this color code...... Thanks for the info and help man I do appreciate it.
03-12-2016, 07:29 PM | #9 |
If you look at the door inner panel some had the code stamped on the in side back side(some had codes for a few colors on then) try to check it out see it your door inner panels do or not.
(saddle sand) is the color you want. or short SAND
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 03-12-2016 at 07:36 PM. |
03-12-2016, 07:38 PM | #10 |
That would be the color part # for the color door panel
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-12-2016, 07:44 PM | #11 |
http://ep.yimg.com/ca/I/yourautotrim...2269_149898214 Buckskin, Santa Fe Would be the closes get them to send you test strip of color
03-12-2016, 07:55 PM | #12 |
Moderator
GM interior color codes are hit or miss because the factory is an assembly point for parts made by multiple different vendors. The colors are more coordinated than one color.
If you have a sample of what you want you can get dye matched to the sample color. The Saddle interior on my 1976 was a fairly dark leather brown color on the dash pad and much lighter sand beige color door panels and other hard plastics with carpet that almost matched the dash pad. The Silverado interior door pockets, headliner, and sun visors are slightly darker than the hard plastic door panels. Take a look at a SEM or Duplicolor color chart locally... don't do it online.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-12-2016, 08:58 PM | #13 |
Getting Old; Going Broke
http://images.tcpglobal.com/chips/19...truck-pg02.jpg
23825 is the PPG number, if they can mix interior paint. Would have to be an old lacquer based mixing system I think. When PPG went urethane, be it DG, DBC or Global etc, they quit doing interior dye colors.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
03-12-2016, 11:28 PM | #14 |
RandyP thank you. I hope then can. I'll make sure I post before and after. Along with process to keep the thread informative. Thanks again!
03-13-2016, 11:33 PM | #15 |
I'm sure sand was short for sandalwood Saddle short for saddle tan
-Cody |
03-14-2016, 11:58 PM | #16 |
Gmc.guy I bow to you on that.
I would have to go throw some books double check
03-15-2016, 07:11 AM | #17 |
Just to keep the post informative, heres the back of my drivers panel
03-16-2016, 01:41 AM | #18 |
Seeing your panels yours might be if you use SEM color coat might be closer to Palomino.
But like I said SEM will send you free color sample or they did few YR ago.
