![]() Join Date: Apr 2015
was interested in only por15 satin With there chassis top coat for uv pro.. I not shure if there top coat will make it shinee .witch I would not like.. im going for a soild nice satin look.. im thinking eastwoods would be great but por15 is buy ready at the paint store.. if any one has a nice clean painted frame post them up.. It was hard to find what products where used on there sites..
Re: Painted Frames post pictures pls... Por 15 - Eastwood .ss paint
haha. I meant to say "what products where used on other forum sites builds"... YES I said it im a member on other sites.. haha..
John Deere Blitz Black
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
This is Eastwood 2K Ceramic Chassis Black.
67 short bed step side build |
Seeing pictures will just show a nice black frame no matter what product is used. Rustoleum will look like any of these shown in pictures. If you were considering POR-15, you should take a look at www.masterseries.com . Their quality starts where POR-15 leaves off.
#6 | |
Not my truck frame, but the frame for my 1958 Buick.
Powder coated in Satin Black: ![]()
Keep your head up...and your stick on the ice. |
Here's mine. It's painted with an industrial urethane, self prime. Made by General Paint. Extremely durable.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
![]() Join Date: Apr 2007
Here's some of my 71 C20 stake body dump. nothing fancy just blasted ,primed with good old Rust Oleum rusty metal primer and painted with Rust Oleum gloss black. Say what you will but I've found it to be very durable. I did the sub-frame on my 69 Camaro in 1986 and its still on there.
#10 | |
![]() Join Date: Dec 2013
The first question should be what are your plans for the truck ? trailer queen /drive to local shows /daily driver / parked in the garage for the occasional ride to town ? Second what is your frame paint budget ? Third how far are you going to take the prep work ? sand blasted to complete bare metal all suspension removed restoration or just a pressure wash cleanup and scuff before shooting it black ? You can spend less than $100.00 and have a nice looking frame over 1 weekend or you can spend weeks and $1,000.00 + to powder coat it after Prep,prep,prep. Asking what do I use will bring 20 answers and none will be specific to what your intentions are without pictures and intended use , Why spend big dollars using expensive rust preventive coatings when it's just a daily driver and that frame already made it almost 50 years ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
MAN!!! these pictures look great.. I AND THE PEOPLE WANT MORE!!
#13 |
Sherwin Williams two part epoxy
#14 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-11-2016 at 12:09 AM. |
#15 |
Only experience I have, no pics, is the POR.
I believe you can top coat it with almost whatever. I hit mine with satin catapillar implement paint. Do it before cured or even still tacky. Durable as hell. Interested in that masterseries if it's that much better. Can't even imagine.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#16 |
I used tractor supply truck and tractor with the catalyst hardener on this frame and it looks great . About $50.00
#17 |
Looks good Grumpy
#18 |
Here's mine, powdercoated satin (low gloss) black. It may not be "correct" but I did spindles, control arm shafts, springs, and steering linkage powder coated in two different greys for variety and contrast.
You can't beat powder, and the cost of entry (which is an acid wash, steam clean, and pre-bake) is worth the job alone. If you could get it clean enough, I'd do: - PPG DP90LF primer - DCU 2060 low gloss clear I'm pretty sure you can shoot clear right over that primer, but double-check. Otherwise you'd need a black color coat in between, but I don't think you do. The DP90 is close to indestructible wherever I've used it. And hard to sandblast off too! Kinda like POR-15.
#19 |
![]() Join Date: Sep 2015
My 70 CST Longhorn is going on this 03 Duramax frame that was pretty rusty. I pressure washed, knocked down what I could, did a rust conversion on it and final coated it with Eastwoods Rubberized Rust Encapsulator. Turned out nice, only time will tell if it will hold up...
#20 |
![]() Join Date: Jun 2009
Some great looking work here guys,
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#21 |
Media blasted , Zinc enhanced Epoxy coated then shot the rails and 2 crossmembers in same color as body (blue) all other parts that will be bolted on the frame from this point shot in a satin black. All Paint coatings and epoxy were from GCI industrial coatings . if you ever done any restoration on anything military.... Army ,airforce ,USN then you will the name Gillespie Coatings INC , they have earned the reputation for very durable coatings .
#22 |
I put second coat on mine yesterday.
#23 |
Wire wheel scuff then por15 with the spray top coat. Satin..
#24 |
#25 |
This is my C10 frame. Not painted yet. I hope to have it primed and painted by the end of this weekend. I already bought implement gloss black. I like the satin on 2manycars2littletime's frame. May consider changing. I also may spend the money and get single stage PPG like I did on the S10 frame.
![]() This pic is of a S10 I did last year. It is a 2015 Mitsubishi color. I can't recall the code or name but it is called Titanium somth. ![]() |
