03-09-2016, 08:27 PM | #1 |
1961 crewcab
factory vin mistake
I ran into something real interesting with my 65 suburban.
The door vin tag is 5Z127476, and when I was working on the front I noticed that the front frame vin is 5Z127475!! after pulling the frame the under seat vin is also 5Z127475, but the 5 has 3 little sideways 1's stamped through it, and above it is a 6! must have been a production error, interesting that they only corrected the one set of #'s though.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-09-2016, 09:06 PM | #2 |
Re: factory vin mistake
Never saw that before.
03-09-2016, 09:28 PM | #3 |
Someone was having a bad day.
I ran the portion of the chassis line in Flint where the VIN was stamped. It is a Federal requirement that the VIN is correct, and we put a lot of effort into making sure that was the case. A few years ago I would have sworn that none got out but I have seen so many in the hobby now that obviously that is not the case. The VIN stamper is a large hydraulic "press" hanging from a tool rail and with the weight offset by a "balancer" (imagine a Harley-Davidson hanging from the ceiling that you are supposed to maneuver into position and press a button). It is supposed to index to the next digit automatically -but - if you mis hit or get out of sequence for some reason then you have to make a repair. Chevy and GMC have different VIN sequence numbers, requiring different stampers hanging there, so if the operator stamps a Chevy VIN on a GMC, for example, then not only is that particular truck wrong but you are out of sequence on every truck after that. The assembly line repair person and/or the "quality man" (the foreman's right hand man) follow the vehicles down the line with an "X" stamp and a 5 lb hammer and correct the VIN sequence number as required. Usually it's not just one truck. It normally takes several trucks before somebody notices, so you'll have five or six trucks that have to be fixed - all without the line stopping - so it's quite a scramble for a few minutes while you figure out what went wrong and what has to happen to make it right. You pray nothing else goes to crap while you've got your two best guys otherwise unavailable. My guess is they fixed what they could and the rest got away. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-09-2016 at 11:10 PM. |
03-09-2016, 10:57 PM | #4 |
But Found Her 25yrs Later!
Interesting find.
. Very interesting assembly line information Keith.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-09-2016, 11:09 PM | #5 |
1961 crewcab
wow! thanks for that info kieth. I love hearing stories about the assembly line and learning how this stuff was built.
03-09-2016, 11:09 PM | #6 |
Very interesting. I wonder what other mistakes the factory could make.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
03-10-2016, 01:12 AM | #7 |
Post Whore
WOW! Sounds like what Normally goes on today! LOL
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-10-2016, 02:10 AM | #8 | |
Nobody figured it out until they went to put the seats in. My uncle once bought a Blazer that had Chevy emblems on the passenger side and tail gate, and GMC emblems on the grill and driver's side. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
03-10-2016, 09:35 AM | #9 |
The possibilities are endless...
Anything that could go wrong will go wrong. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-10-2016 at 10:14 AM. |
03-10-2016, 09:40 AM | #10 | ||
The repair man cut the hole with a hammer and chisel riding the truck down the final line, while the cab was teetering on top of the shift tower. We also used to keep a library of tire/wheel assemblies at the install location in case you received a vehicle with the wrong axle. You could install the corresponding wrong tire/wheel so that the vehicle could continue out back, where the axle assembly would be replaced in heavy repair. Quote:
For me, roughly every ninth vehicle on the line was a GMC. The fenders, hoods and rad support/grille were all built up and trimmed out in a separate, remote area of the plant - per the build manifest - and conveyed in sequence to the main line. Nobody saw both sides of the build at that point so it wasn't obvious that anything had been screwed up until all those pieces came together on the final line (at which point it became painfully obvious). Line rate in Flint was 60 jobs per hour, or one complete truck every minute. That's why it was so easy to mess up: you'd get in the "zone" after your 300th truck that day and if you weren't specifically paying attention you'd likely put a Chevy emblem on a GMC, just from being on autopilot. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-10-2016 at 10:09 AM. |
03-10-2016, 09:50 AM | #11 | |
Recent discussion: http://67-72chevytrucks.com/vboard/s...d.php?t=682275 My intro thread: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Old Wive's tales from other GM workers: http://forums.maxperformanceinc.com/...d.php?t=556607 Growing up in a GM family: http://forums.maxperformanceinc.com/...d.php?t=560524
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-10-2016, 01:45 PM | #12 |
Now that is a big mistake!! lol
03-10-2016, 01:58 PM | #13 | |
03-10-2016, 07:06 PM | #14 |
Sounds like a Johnny Cash remix.
03-10-2016, 08:27 PM | #15 | |
Who Me?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
