86 C10 2wd 6.0 6L90E (Long Tube Header Advise)
Guys.
I need your expertise. I have an 86 C10 2wd Single Cab Short bed. I am in the process of installing a 6.0 and 6L90E, not an 80E... Everyone seems to think I make a mistake by saying 90E... But it's a 90. Anyways, my question is, does anyone know of any Long Tube Headers that I can purchase that will fit without me having to notch the frame on my truck, or heat and bend the headers. You know "Direct fit bolt in and go" long tube. I have searched high and low, read almost everything there is to read on this forum, and haven't been able to find the exact answer to my question/application. I keep seeing everyone has a 4L this or that trans and what they're using for headers, but not much on the 6L Trans. I have contacted several header manufacturers and they all say that they have only test fit their headers on swaps with the 4L series trans. Getting pretty frustrated at this point ![]() |
#2 | |
Re: 86 C10 2wd 6.0 6L90E (Long Tube Header Advise)
The only variable you need to consider that will determine the ultimate fitment of the headers in your truck besides that is the inclination angle you install your engine/trans at. For example, If the headers were designed to be installed with the engine inclination angle set to 4 degrees and you install your combination at a more severe angle to allow the taller case height of the 6L90 trans to clear your floor without cutting it, then the collectors will be angled more towards the ground then they were intended to be. The Hooker 73-87 GM truck LS swap headers will fit your truck and transmission, but their bend geometry is only compatible with the matching Hooker engine mounting brackets. |
#3 | |
I have This: 12646HKR 12645HKR I need this? 12621HKR 2334-1HKR 70501414-RHKR Thanks for all the help Todd! |
#4 | |
#5 | |
Yes, you've got it straight. Keep in mind that the horizontal alignment of the headers to the exhaust system is dependent on the engine inclination angle provided by the Hooker transmission crossmember for any of the transmissions covered under the application. Since your 6L90 is a custom application, you may end up with an angular discrepancy at the header-to-exhaust system connection if your engine inclination angle is different than what was arrived at for the other transmissions.
#7 | |
#8 | |
#9 | |
#10 | |
#11 | |
Here's some update pics of what we had to do using the hooker engine mounts, long tube headers, and the cross member. Totally had to massage the floor. But a high hump tunnel truck would probably clear the 6L90 trans no problem. Didn't use the cantilever bracket on the trans and cross member..the angle was off.
#13 |
Two more since I can only upload 5 at a time
#14 |
As a helpful observation to you, the way you have the crossmember installed is backwards from its intended design geometry. The side with the bolt-on foot goes on the passenger side frame rail, which positions the plane of the center beam with its angle sloping down towards the rearend to correspond with the down-angle of the engine. The headers seem to fit your trans well.
#15 | |
Headers fit great!! |
#16 |
You will have to recheck your angles and possibly shim the trans mount by some amount, but the mount face will be far more parallel to the surface of the cross beam. The mating surfaces of the mount and the cross beam are not on the same plane the way you have it installed now.
#17 | |
#18 |
#19 |
