Old 09-24-2003, 10:46 AM   #1
sactoC10
71 DELUX
sactoC10's Avatar
heavy duty factory rear coils
Anyone know the specifics of the rating / payload differences of the regular factory rear coil springs and what Chevrolet installed as a "Heavy Duty" rear coil spring in 1971?
sactoC10 is offline   Reply With Quote
Old 09-24-2003, 11:01 PM   #2
slam33
slam33's Avatar
If it's a 1/2 ton, they use a 3/4 ton spring. Problem is I did the front end on mine a did a 3/4 ton spring, I also had 3/4 ton springs on the rear. The damm thing has a harsh ride to it. I thought it would just be a solid feel but it's not unless you load the bed down with about 300 lbs.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-25-2003, 01:47 AM   #3
sactoC10
71 DELUX
sactoC10's Avatar
I was simply curious, since my build sheet says that mine came with Heavy Duty springs, front and rear. It also had helper leafs in the rear when I bought it. I removed those quickly.
I swapped out the stcok coils (rear) for a set of Eibachs. I was thinking about selling my stock rear coils, but now I am thinking I'd better keep them! They could come in handy should I ever want to carry a serious load or pull something.
