03-11-2016, 09:42 PM | #1 |
Leaf Spring Dimension for a 12bolt
Does anyone have a 73-87 truck 12bolt (10bolt would work to) that they can measure the distance between the leaf spring mounting pads on the housing @ the centerline of each pad?
03-11-2016, 10:27 PM | #2 |
Re: Leaf Spring Dimension for a 12bolt
03-11-2016, 11:12 PM | #3 |
Thanks! Looks like ~43" is my number.
03-12-2016, 08:26 AM | #4 |
If I remember 1\2 and 3/4 tons are 42-1/2" and 1 tons are 40-1/2 give or take a 1/2. Found this out the hard way going to a 1 ton frame from a 1/2 ton
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
