Power steering threads
Can anyone tell me the thread size on a mustangll rack & the Sbc 350 pump? Thanks
yoshi's 49 project |
Re: Power steering threads
inverted flare on most gm pumps
metric o-ring seal on the rack any hose place can do the inverted flare buy the adapters for the rack to go to AN flare they should be 2 different sizes http://streetperformanceusa.com/i-71...ering-box.html ![]() http://streetperformanceusa.com/i-71...ering-box.html ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
GM pumps from 95 or so and newer tend to have the metric O ring flare. This fitting is also known as a "Saginaw Fitting" in some places. If your pump has this fitting it is most likely a 16mm version.
The metric threads on the rack are 14x1.5 & 16x1.5, anyone know which one is the return? Thanks
without looking... the return is typically bigger
hang on to your steering wheel when you fire up the motor if your hooked up backwards the wheel will go violently to one side even air in the system can cause unexpected movement ![]()
Ok thanks Ogre
Here's a good drawing
http://www.classicperform.com/TechBook/ps7.jpg And some more good info http://www.classicperform.com/TechBo...ngTechTips.htm |
PDF file here and it explains different part numbers
http://my.cardone.com/techdocs/PT%2022-0007.pdf
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
Great thread lot's of good info
. Thank you . ........Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Picked up a pump today
Looks like something missing out of here
But found these in the box of bits, are these needed? Thanks
#13 |
That is the pressure metering valve.
There are different ones that provide higher and lower pressure depending on whether you are running a recirculating ball or a rack steering unit. The rack will take about 1500 psi where the recirculating ball style typically wants to see about 2300 PSI. When I put my 57 together, the pressure was too high, and I looked up some part numbers at the chevy dealer, and bought the ones that were the lowest pressure for that style pump. Also, I am running a hydroboost. the pressure was too low for my brakes, and I had to go back up. My steering is just really sensitive with the higher pressure, but I would rather be rocking the steering wheel a little instead of looking for places to land. I also have the recirculating ball style steering box. The pump you have is called a GM type 1 The ones for the racks are typically a type II. If I were you, I would try my luck at finding a type II pump and bracket out of maybe a 86-91 Corvette since it was made for higher volume and lower pressure. That pump will work, but you have to fiddle with the spring pressure to get the pressure down. Higher spring pressure = higher pressure. you may be able to stretch the spring to weaken the tension, and then cut it back to the original length. I would try to get another spring so that if all else fails, you still have a known spring to install for a given pressure. The ones I was working with, one had a splash of purple paint, one had green, and one had white. I ended up using the one with the white paint on it. I remember that there is an O ring under the nut/fitting that screws into the body of the pump, so if you don't have it, don't fill it until you get one
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 04-01-2016 at 05:02 PM. |
#14 |
How's the pressure metering valve go together?
#15 |
Looks like it's the valve then Spring followed by 10.470 -4 then -5 then -3, are these parts available?
#16 |
taking a second look at that diagram part 10.470-3 is on the end of the hose.
I spoke to the seller of the pump he said it came off his Hudson car fitted with sbc to Mll rack & worked perfectly, he just wanted the chrome setup
#17 |
I'd be suspicious.
Looks like when he got his chrome setup that the pressure was off, and took the parts out of the pump he sold you and put the innards off the chrome stuff in the box that you got
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
#18 |
I have two or three of those pumps. I have early and late. There's a steering place I know of, and I will get you their Email, so you can talk to them directly.
These guys modify power boxes to fix any sort of problem. They would be a good source of info if you want to try. Chip@powersteering.com
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 04-01-2016 at 07:14 PM. |
#19 |
They modify old cars to get the power steering working right. pumps, pitman arms, idler arms, racks, etc.
They are in Branson Missouri chip@powersteering.com
#20 |
All you need is a steering flow valve like this one. Speedway, Mullins, Borgensen all carry them.
http://www.speedwaymotors.com/Mustan...-GPM,5852.html
