Old 03-12-2016, 07:55 PM   #1
MAC-MAC
Help Figuring out Best fuel tank to use.
My Project is a 58 Apache with a 305 TPI engine and a 700r4 tranny. Relocating the fuel tank is a must and I am trying to figure out the best way to go. I am looking to place a side fill tank behind the rear axle between the frame rails. would like to find a tank that would work with the least amout of modifications. New or pulled I need to find one that will work any suggestion or thread listings are greatly appreciated.
MAC-MAC is offline   Reply With Quote
Old 03-12-2016, 08:32 PM   #2
_Ogre
_Ogre's Avatar
Re: Help Figuring out Best fuel tank to use.
i run a no limit tank with internal pump
the price has a major increase since i bought mine 10 yrs ago
http://www.nolimit.net/products#!/Fu...tegory=6157546
side fill
shop air compressor timer
Old 03-12-2016, 10:27 PM   #3
Advanced Design
Advanced Design's Avatar
Mac, also there are probably build threads on here that will help out.
Another option is to look through fuel tank dimensions http://www.tanksinc.com/index.cfm/pa...ctory/home.htm
To find one that will work.
Advanced Design is offline   Reply With Quote
Old 03-13-2016, 09:34 AM   #4
47 Fasttoys
47 Fasttoys's Avatar
I used a tank from a '93 Chevy van. 32 gallons, pump and sender included. It hangs a little low but has never been an issue. In my case I use a bed fill but it could be set up for fender fill. I'm running a TBI engine in my '46. I've been running this set-up for years with no issues.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 03-13-2016, 01:48 PM   #5
Speedbumpauto
Speedbumpauto's Avatar
What kind of tank threads are almost as popular as the "what have you done" threads. They all have some drawbacks from either a functional or asthetic standpoint......or both, including mine. You can find threads on a couple of us who have done Tanks units with internal pumps and different methods of side fill.
MANY have done mustang tanks and IMO, they have problems too. Mine hangs slightly lower than I like but easy to install. Holds slightly less than I'd like, but at my age it will go further than my bladder. It DID cost more than lots of others I've seen. I will say it FILLS great and I've done a couple before that were not so good and I would NEVER put a fill in the bed. And there you have it.
Speedbumpauto is offline   Reply With Quote
Old 03-13-2016, 10:41 PM   #6
roger55
roger55's Avatar
Here's what I did for my 3200 89" long bed.
I have the same tank as Speedbump. Got the idea from him. I did mount mine up just a little higher than he did though.
It's from Tanks, Inc.
http://www.tanksinc.com/index.cfm/pa...prod/prd73.htm
It's perfect for those that don't want to fill from the bed.
What I did for my fill was to cut out the original flange in the cab and found a place on the rear fender with a similar curve and welded the flange in there.
I also tucked this tank in up as high as I could for clearance:
roger55 is offline   Reply With Quote
Old 03-14-2016, 01:21 PM   #7
57chevyman
57chevyman's Avatar
I got a new '65 mustang tank from tanks inc. better than an original mustang tank because the feed is on top and not the bottom. it fits pefect and doesnt hang low.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
