Old 03-12-2016, 09:05 PM   #1
jnf2k2
np 203 part time conversion help
Pulled a what i'm sure is a np203 from a trunk in a junkyard today and need help identifying if it might have had the part time conversion done previously. Obviously there's no way to tell from the outside, but what can i do to confirm? If it's been converted there should be 4 shift positions now, or still 5? Any help would be appreciated.
jnf2k2 is offline   Reply With Quote
Old 03-13-2016, 09:25 AM   #2
CrewCab59
CrewCab59's Avatar
Re: np 203 part time conversion help
The Np203 is afull time transfer case all four wheels receive power at all times. The shift pattern for this is:
Front towards the dash.
Low Loc
Low
N
HI
Hi Loc
With this Hi is your normal driving position. All four tires are driven, but the front and rear axles are driven independent from each other. They are free to turn at what ever speed. This is done thru a differential in the transfer case like the one in your axle , by shifting to Hi Loc you are still in Hi range, but, the front and back axles are now locked together and turn at the same speed. The Lo and Lo Loc only using a lower range gear in the transfer case.
There are few different kits made over the years , 1st locking hubs are now able to disconnect your front axle from the wheel.
Lo Loc
Lo
N
2 HI
HI Loc
The HI Loc has become 2 HI. The differential in the transfer case has been"disconnected" so it will not drive the front axle.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
