Are Ac Delco R45TSX factory plugs in an 87 350?
That is what I pulled out of mine making sure before I put the wrong plug in I want in exactly what it came with new.
Thanks Last edited by weider1717; 03-12-2016 at 10:25 PM. |
Re: Are Ac Delco R45TSX factory plugs in an 87 350?
R43TS, CR43TS, 41-817 (platinum) or 1 (Rapidfire). I looked on eBay for a set of NOS ACNITER II plugs for my 75.
Current GM 350 crate engine spec says R45TS is recommended plug.
Rich Weyand 1978 K10 RCSB DD. |
Thanks I couldn't find anything on it and these look so old I bet they're original to the truck it has 69k miles on it.
I found paperwork where the plugs were replaced in 1996 with the R45TSX that I pulled out.
Anyone care to give their op on these plugs? From my research the X for extended gap was used more in like 1975 years of smog stuff got big and are not for this truck but not 100%. Thinking I need R45TS and not R45TSX anyone? Last edited by weider1717; 03-13-2016 at 05:48 AM. |
R45TS what it was out of the factory. It's been some time since I have did a older plug change. But If I remember one a hotter plug one is a colder plug. If go to auto store that have them on a rack you will see the one has the electro sticking out more( hotter plug ),
one electro is in side the thread part of the plug a ( colder plug ) when you doing a tune up in you plugs to brown or to milky white you would put in plug get the electro closer or away from the piston to get a better burning plug. when using header run hotter so some time you need a colder running plug. This is also depends on carb or EFI setting & checking plugs.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Run with the R45TS. It will be just fine.
Current Projects: 1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion 1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently. |
From the parts book. Not sure if production or replacement.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
Thanks! Looks like the book calls for R43TS for an 87 350 tbi. Thats what I'll run with unless someone says otherwise.
Did read the 45 burns hotter and stays cleaner |
Emphasis, mine. For a mostly stock application, I'll suggest hotter plugs. If it's a monstrously built engine, more often than not, I never had to make a suggestion, the customer had his or her ideal plug choice, already.
The Vin K (TBI) engines of that era (87-95) came with CR43TS. NGK UR5 is a good alternative.
#13 |
#14 | |
#15 |
#16 |
The heat at which the plug runs goes up with the number for ACDelco plugs.
A 45 will be less prone to fouling than a 43.
| Bookmarks |
