Old 03-12-2016, 11:12 PM   #1
Isaiah92260
Isaiah92260's Avatar
Brand new brake master cylinder failed, help!
I bought a round top Brake Master Cylinder. Assuming that was the right part I needed, my fault for going to AutoZone I guess. The only had the round top single master cylinder and a dual master cylinder. I have the 1 1/8th single master cylinder with the square top originally.... After doing research and a lot of brake bleeding, the new round top would not work! Also found out that the round top is 1 inch bite and the original square top Style is 1 1/8th bore.... Pedal down to the floor, I adjusted the push rod all the way and I had 2 inches of play before it started engaging..... Where are can I find the square style master cylinder? Or do the still make them? Or are there any more alternatives I can try before I attempt to return the brake master cylinder to autozone? Are longer brake push rods?
Isaiah92260 is offline   Reply With Quote
Old 03-12-2016, 11:36 PM   #2
cv65
cv65's Avatar
Re: Brand new brake master cylinder failed, help!
rockauto has them,http://www.rockauto.com/en/moreinfo....1324280&jsn=17
cv65 is offline   Reply With Quote
Old 03-13-2016, 04:50 PM   #3
Isaiah92260
Would it be a good idea to rebuild the original master cylinder with one of the kits on rock auto?
Old 03-13-2016, 05:17 PM   #4
cv65
cv65's Avatar
probably easy to just get the complete one and put it in.I dont know price differance,by the time you buy kit,brake hone if you dont have one,make sure you bench bleed it, good luck, probably a u tube video on how to rebuild master cylinder,and bleed all four wheels
Old 03-13-2016, 08:02 PM   #5
PGSigns
PGSigns's Avatar
I think if I needed a master for one I would do the update to the duel pot and split the system. Cost is not to much to do it and the added safety is well worth the money.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-13-2016, 08:57 PM   #6
Slow Build
Slow Build's Avatar
x2
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-13-2016, 09:51 PM   #7
Isaiah92260
Thanks guys. I have to take my truck on another 120 mile trip this coming weekend and I'm not gonna have the time to do a whole dual master cylinder job because I drive the truck everyday to work, that's why I was thinking about slapping in a new one or a re build it cuz that'll only take me a good 1 in a half after work. Mostly likely get a new single for now and then do a dual cylinder job when I have a good weekend to myself
Question:
How do you bench bleed?
Old 03-13-2016, 11:31 PM   #8
cv65
cv65's Avatar
Jimmy
I agree,its money well spent,I personally would even mess with a single,and if I had one Id change it ,not that expensive and may save you in the future especially if its your daily driver,
https://www.youtube.com/watch?v=kEPXgDGU6_0
how to bench bleed
Old 03-14-2016, 12:17 AM   #9
Isaiah92260
how to bench bleed
Definitely, I have a 67 dual master cylinder a buddy gave me, I found the "splitting the lines" build thread, is was planning on getting the fittings and lines and try knocking it out on a good weekend.... Thanks
