72 c10 with rear leaf springs question
So my truck was set up with a tow,hauling, package from the dealer so it has leaf springs on the rear. I haven't had any luck finding lowering kits that have what you need for rear leafs for a 72 C10. They list kits for 1973 C10 will that work? I would look under suburban or C20 C30 but the rear end might be different I'm not sure. Any help is appreciated!
![]() Join Date: Apr 2012
Re: 72 c10 with rear leaf springs question
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
#3 | |
Welcome to the odd ball 2 1/4" wide rear spring club. There expensive.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
the leaves are skinnier than 73 and up...got mine made by eaton detroit spring...it was years ago ,i think they were about 350 for the pair....you can use later shackles if you tack weld washers inside on the spring end...the end that fits on the chassis bracket is the same
1970 short step c10 leaf spring 454 |
![]() Join Date: Mar 2007
I have a complete rear leaf lowered with axle flip and rear axle. How soon do you need everything? I am wanting to swap to coils. They ride to rough for me. If your not in a hurry.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#7 | |
Billsauer@gmail.com |
