Old 03-13-2016, 08:05 AM   #1
Fiftee3
Fiftee3's Avatar
MII lower control are brace/gusset
I am coming along on MII install. My question is there is a small triangle steel brace that gets welded to the rear steel crossmember tube to the crossmember.
I have read this is a weak point or area of possible failure. Would it be better to make on that is the length of the steel sleeve, but elongated on the end that welds to the crossmember? Like 6" or so? I'm no engineer, maybe the one supplied is enough. Maybe the failed ones were not welded properly?
In the photo below, I'm talking about lengthening the side toward my thumb. Your thoughts? Am I worried about nothing here or overthinking it?
Fiftee3 is offline   Reply With Quote
Old 03-13-2016, 08:12 AM   #2
Fiftee3
Fiftee3's Avatar
Re: MII lower control are brace/gusset
Like this maybe?
Old 03-13-2016, 09:44 AM   #3
47 Fasttoys
47 Fasttoys's Avatar
Maybe a little of overkill, mine has no brace and has had no issues. Mine is a Fatmans front end.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 03-13-2016, 09:52 AM   #4
mphudak
i would use the one it came with then add a rear support something like this, which is what I did to mine (not a pic of mine, just swipped from the web). That triangle supports the stress in only one plane. If you research crossmember failures you'll find a number of them.
Another option
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 03-13-2016, 11:48 AM   #5
Rude Dude
Rude Dude's Avatar
This is what I did double sheer design
Rude Dude is offline   Reply With Quote
Old 03-13-2016, 12:45 PM   #6
_Ogre
_Ogre's Avatar
27,000 miles on the fatman mustII in truk without a worry
i try to get truk on a rack once a yr to check over all of my welds
shop air compressor timer
