Old 03-13-2016, 10:10 AM   #1
joe Diego
8lug c20 drop (I've searched)
I've been searching for the past couple days but there is not that much information on lowering an eight lug custom camper 1971 c20 Chevy truck. For the past month I've been reading a lot about these trucks and I would like to lower it about 6 inches in the rear. I think there's about 8 leaf springs in the rear. Would removing a few leaf springs and adding drop spindles to the front give me at least a 5 inch drop all around?
joe Diego is offline   Reply With Quote
Old 03-13-2016, 03:48 PM   #2
mike16
Re: 8lug c20 drop (I've searched)
perhaps because they are valuable in origonal shape?
mike16 is offline   Reply With Quote
Old 03-13-2016, 05:26 PM   #3
joe Diego
Blah, it's my truck, it's not a 4x4 and I want to lower it.
Old 03-13-2016, 05:48 PM   #4
cadillacart
1972 C/20
cadillacart's Avatar
Hey Joe,
I flipped the axle and removed all leafs except for three or four and cut two coils off of the front springs to get the stance you see in the photo attached.
CPP c-notches were used to give travel room in the rear.
I think two coils off of the front is too much also. I plan to put real lowering springs and lowering spindles on the front and also re-install the full leaf spring pack and use lowering blocks to get the ride height where I want.
I hope this helps!
PS - here are a couple good threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=403279
http://67-72chevytrucks.com/vboard/s...d.php?t=419051
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 03-13-2016, 06:04 PM   #5
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Years Ago I spoke with National Spring Co. in Santee and talked to them about De-arching the springs. I eventually decided to wait because I will probably convert to a 5 lug rear and go with a 4 link.
good luck
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 03-13-2016, 10:05 PM   #6
Ram-Man
Ram-Man's Avatar
You could always bag it. http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
