Old 03-13-2016, 07:49 PM   #1
cst204x4
Headliner trim
What is the best source/manufacturer for headliner trim. Or is there a good place to get the plastic replated?
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 03-13-2016, 08:13 PM   #2
vidman
vidman's Avatar
Re: Headliner trim
I purchased mine from GMCPauls. The fit was perfect and looks great..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-17-2016, 04:04 PM   #3
TKCR
TKCR's Avatar
Re: Headliner trim
If you have a good set, just re-dye/paint. I had maroon and changed my interior color to grey/charcoal. Just clean and then use lacquer thinner to wipe down the parts and then clean with soap & water again. After it throughly dries, start painting.
I didn't have before & after pics of my other trim, but here's a pic of the a-pillar trim I got from LMC with the tweeters. They come black but I painted/dyed just like my maroon headliner trim with the charcoal.
Old 03-17-2016, 04:07 PM   #4
TKCR
TKCR's Avatar
Re: Headliner trim
Well I did have this pic. This is after painting and re-installing in the truck. Even did the visors, dash pad & door panels with the same stuff.
Old 03-17-2016, 05:16 PM   #5
Grumpy old man
Grumpy old man's Avatar
Re: Headliner trim
Well... use dawn dish detergent to wash them, Then MEK if you don't have MEK use some lac thinner , Then use BULLDOG adhesion promoter very lightly a little goes a long way . if you don't use BULLDOG or a comparable product it will just peel off and your just wasting your time .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-17-2016, 05:29 PM   #6
cypressbog
Go Pack Go!
Re: Headliner trim
Check out these websites. Contact the company to see if there is a vendor using either sprayon or futurechrome near you.
You can try the Eastman product, but I have no idea how well it works.
http://www.futurechrome.com/
http://www.eastwood.com/ew-liquid-ch...MgPRoCY9jw_wcB
http://www.sprayonchrome.com/Gallery.html
cypressbog is offline   Reply With Quote
Old 03-17-2016, 07:41 PM   #7
57larry
Re: Headliner trim
can you just glue the headliner without using the trim? I have a headliner for my 68 but no trim
57larry is offline   Reply With Quote
Old 03-17-2016, 07:52 PM   #8
Grumpy old man
Re: Headliner trim
Where is this thread going , your talking about 2 different models of trucks
Old 03-17-2016, 10:30 PM   #9
57larry
Re: Headliner trim
67-72
