Old 09-24-2003, 03:42 PM   #1
jewels.
jewels.'s Avatar
bench seat mobility...
hi all!
has anyone ever rigged up their stock bench seat to tilt forward so you can access the area by the gas tank and where the stock jack would go???
the pic below is a view from the passenger side of the bracket on the bottom corner of the bench seat. there are two screws that keep the seat immobile (so it wont tilt).
was talking with andy (longhorn man) yesterday, and wanted to see if anyone has ever done this to their bench seat. he has done this by removing Screw1, but the problem is, if you remove Screw 1 from the bracket, the seat will not only tilt forward, it will also tilt backwards against the back wall.
has anyone ever hooked up the seat to allow it to tilt forward, and to NOT tilt backward? what would be the damage if i allowed the seat to tilt backward? i generally sit with the seat pretty close to the back slot position anyways (even though i am only 5'5"), but i dont want to damage the paint on the inside of the cab because the seat would rub against the back wall...
ideas?
any comments on the function of aftermarket bench seats? how do they accomplish this feat?
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 09-24-2003, 03:42 PM   #2
jewels.
jewels.'s Avatar
oops - forgot pic....
Old 09-24-2003, 03:45 PM   #3
jewels.
jewels.'s Avatar
hmmm - i should be more clear about this picture...
as i see it (i think).... screw 2 is the pivot screw if you remove screw 1, because screw 2 only bolts into the bottom part of the bench seat....
but screw 1 bolts from the bracket into the top part of the bench seat (which holds it immobile)
i was *thinkin* about riggin up some kind of secondary bracket (even a duplicate bracket or somethin) that might prevent the seat from tilting too far back... but i wanted to see what others have done to fix the problem....
comments? suggestions?
jewels.
Old 09-24-2003, 03:45 PM   #4
Piper71c10
Unending Project
Piper71c10's Avatar
That's a great question Jewels. I'll follow this thread closely to see if there is a way.
Piper
Piper71c10 is offline   Reply With Quote
Old 09-24-2003, 03:47 PM   #5
busterwivell
I've got a bench seat from an early 80s truck in mine and it tilts forward.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 09-24-2003, 03:56 PM   #6
jewels.
jewels.'s Avatar
do you know how it tilts forward?
i refuse to change out my bench seat because it has been custom re-upholstered (its fancy), and i love it to death... i'll attach some pics.....
so i would prefer to modify my seat instead of replace it...
jewels.
Old 09-24-2003, 03:57 PM   #7
jewels.
jewels.'s Avatar
another pic....
check out the link below for a bunch of pictures (that are larger)
Old 09-24-2003, 04:06 PM   #8
sactoC10
71 DELUX
sactoC10's Avatar
Wouldn't ya think that there is some way to stop the seat from hitting the tank or the rear of the cab with some sort of "stopper" above the tank?
sactoC10 is offline   Reply With Quote
Old 09-24-2003, 04:08 PM   #9
Hooter
My other Love
Hooter's Avatar
seats from 73-87 chevy trucks have a latching mechanism in the side that keep it in place. Ever thinkof pulling screw 1 out , putting a pice of rod in its place with a washer welded on one end to keep it from pulling out, then have a sping attached on the other end with a handle to pull the rod out when you need to pull the seat forward, then the rod goes back into the hole to keep the seat in place.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-24-2003, 04:18 PM   #10
67chevemall
67chevemall's Avatar
I think I would go with the stopper idea
Even just bulldogging a thin piece of wood to the tank or cab wall would do it!
Cheers
Glug Glug Glug!!!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-24-2003, 04:22 PM   #11
Slammed67
Progress = 0%
Slammed67's Avatar
My '67 bench seat folds forward. It has a bracket (and adjustment screw) that prevents it from moving back. You can adjust the angle of the seat back to a certain degree. I'll try to take a picture this evening and post it here. By the way, it is the stock '67 seat.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-24-2003, 04:22 PM   #12
sactoC10
71 DELUX
sactoC10's Avatar
Or maybe just replace that screw with something a bit more easy to unscrew?
Hmmm, probably lots of options if you go that route. Jewels, what would you think about a small button or incision or precise hole in your cool seat cover?
Old 09-24-2003, 04:26 PM   #13
jewels.
jewels.'s Avatar
wow - you guys are awesome!
there are all kinds of ideas here....
the hole in the cover doesnt big me as long as its cleanly done (i can do that - i'm a women, and i sew!)....
i like the idea of a more temporary screwed in bolt or even a rod - which would allow the seat to tilt forward....
also - i would REALLY be interested in the pics of your 67 bench seat, and how they hooked up their mechanism...
keep the ideas coming!
this is great!
jewels.
Old 09-24-2003, 04:32 PM   #14
Red68
Red68's Avatar
Jewels, my stock 68 seat(at least I think it is stock) tilts forward and I did not modify anything. I attached a pic of how it works. Maybe you could weld a stop on the seat frame, although that might be a problem since you have it upolstered.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-24-2003, 04:52 PM   #15
smitty62
smitty62's Avatar
Jewels; As I understand it any of these benches can be modified to do what you want by adding an adjustment bolt and pad to the seat support--some came from the factory with this to adjust the "pitch" of the seat back. However, I've also been told the original upholstery on the more deluxe trucks would not allow this. I'm going to try posting a pic here(Be gentle, it's my first time) showing what I understand is the original style upholstery on the deluxe trucks. As you can see, the cover over the steel seat supports won't allow the seat forward
(img)
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 09-24-2003, 04:53 PM   #16
rickspickuppart
I seen a guy that used one of those pins w/ the release button on the end of it, I saw another one where a guy used a real big chrome "wing-nut" style bolt (have no idea where he got it from)
rickspickuppart is offline   Reply With Quote
Old 09-24-2003, 04:57 PM   #17
Red68
Red68's Avatar
sorry, forgot the pic. here it is.
Old 09-24-2003, 04:58 PM   #18
CPNE
Resident Curmudgeon
CPNE's Avatar
There were 2 syles of bench seats. One, call the full foam seat has the fixed back as your descibe and is the only seat available after 68 I think. The other, which was standard in 67/68, with the full foam being optional, is the one Slammed67 descibes. it does fold forward. It has a thin pad (not full foam) and has arched springs to make it's shape.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-24-2003, 05:01 PM   #19
jewels.
jewels.'s Avatar
this is really really really really REALLY useful information - you guys are awesome!!!
i am not for certain that when i picked up my bench seat that it was specifically from a 1968.... it was jsut the proper color and make/model of seat --- who knows what year truck it came from....
i think i am going to go lookin in the junkyard for a bench seat that folds, and try and take the brackets off of one of those to adapt to my seat ----
sound like a plan?
cool!
jewels.
Old 09-24-2003, 05:21 PM   #20
palallin
Loosen, rather than remove, Screw 1. Cut a slot in the bend of the bracket below Screw 1. You could then fold the back forward, but the bracket resting on the loosened screw will not allow if to tilt back. If the slot weakens the braket too much, it could be doubled or replaced with a bracket fabbed from thicker steel.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-24-2003, 05:23 PM   #21
jewels.
jewels.'s Avatar
oh wow! that is so the ultimate solution!!! are you an engineer? i am, and i am jealous because i should have thought of that solution first!!!! you are so cool!
thanks!
jewels.
Old 09-24-2003, 05:51 PM   #22
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I have 2 factory folding bench seats, both in exelent condition. One is black with red trim and the other is the bright green with cloth inserts. I would take $75.00 each for them and have pictures if you want. These might be tough to ship also. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-24-2003, 05:56 PM   #23
jewels.
jewels.'s Avatar
thanks wes, but as i said before, my bench is specially covered, and i dont want to get rid of her...
here is what i'm thinking for modification of my existing brackets....
just remove screw 1, cut this slot for screw 1, and put a screw or bolt back in place....
we will see if it works...
jewels.
Old 09-24-2003, 05:57 PM   #24
Classic Heartbeat
No problem, Good luck. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 09-24-2003, 06:30 PM   #25
palallin
In turn, thank you! I'm an English prof/college administrator . . .
