Old 03-13-2016, 10:03 PM   #1
jbharkjr
Lowering Kit for 1986 C10...4/6 Drop
Ready to lower my 86 C10 and with all the different options available, just looking for some input on what would be the best setup.
I am looking at the Belltech kit (BEL-705SP) primarily and just wondered if anyone had any better suggestions or if this would be a good kit that would also achieve good ride quality? I like the idea of a single kit that has everything although I know sometimes you can achieve better results by piecing a kit together.
Thank you in advance!
jbharkjr is offline   Reply With Quote
Old 03-13-2016, 10:18 PM   #2
Rascal_one2001
Rascal_one2001's Avatar
Re: Lowering Kit for 1986 C10...4/6 Drop
It's a good kit I had to bend my brake lines a little different to clear spindle. Make sure you get the correct spindle size so you don't have to replace all your brakes.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 03-13-2016, 10:30 PM   #3
jbharkjr
How are the street performance shocks? Ride smooth? I had read the Nitro shocks suck and go out rather quickly.
Thanks for the response.
Old 03-13-2016, 11:29 PM   #4
bbbc10
Diggin The SquareLife
Go with western chassis spindles and springs up front and belltech flip kit in the rear i had belltech shocks on mine as well oh an get some rear shock extenders and u will be good to go
bbbc10 is offline   Reply With Quote
Old 03-14-2016, 05:03 PM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
This is a great kit too. Travis (Pro Performance) is a forum vendor on here too!
https://www.azproperformance.com/McG...150-93151.html
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-16-2016, 09:32 AM   #6
jbharkjr
Thanks for that! I'd much rather buy from someone that supports the forum as well.
