Old 03-14-2016, 11:05 AM   #1
chrismoore701
chrismoore701's Avatar
Bringing up Stepside gas filler hose again
Getting ready to buy my stepside gas filler hose. I found one at Classic industries for $22 or so. I have dual tanks and planned to buy two and cut one up and twist it to work for the other side. Does any one have any other ideas how to handle this?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-14-2016, 01:20 PM   #2
NJ C10 Guy
Re: Bringing up Stepside gas filler hose again
What year is your truck? Also, let me know if it works!
NJ C10 Guy is offline   Reply With Quote
Old 03-14-2016, 01:21 PM   #3
chrismoore701
1979
Chris
Old 03-20-2016, 09:30 AM   #4
chrismoore701
What else have you guys done to the hose on the second tank to get it to fit?
Chris
Old 03-20-2016, 10:14 AM   #5
chrismoore701
Why not just get a radiator hose to fit?
Chris
Old 03-20-2016, 02:58 PM   #6
chrismoore701
What about something like this. There are multiples sizes
http://r.ebay.com/dNJf4i
Chris
Old 03-20-2016, 03:15 PM   #7
Jaysonb
Jaysonb's Avatar
I think that you could use exhaust tubing for the bends, and connect it with the hose that is in that ebay ad you posted.
Jaysonb is offline   Reply With Quote
Old 03-20-2016, 03:36 PM   #8
tucsonjwt
If you search online you can find semi flexible fuel filler hoses of different diameters. Some of the hoses have a wire molded into the core to allow it to be bent and keep its shape (somewhat.) Look for flexible fuel filler hose. Don't use radiator hose - it is not designed for fuel. Race cars and cab and chassis utility trucks often use this hose.
tucsonjwt is offline   Reply With Quote
Old 03-21-2016, 08:33 AM   #9
Greenlee
Greenlee's Avatar
One problem with using a flexible hose, is the factory hose is a different diameter on each end. I'm not sure if all year models were like that. I know mine was.
Greenlee is offline   Reply With Quote
Old 03-21-2016, 09:34 AM   #10
chrismoore701
I did a quick check on the diameter and they seem to be the same, but I need to look a little closer before I order. That stuff on ebay is like $0.99 per inch, not a bad price.
Chris
Old 03-23-2016, 07:09 PM   #11
NJ C10 Guy
Radiator hose is no good. The gas will deteriorate the hose. They are made differently.
Old 03-23-2016, 08:21 PM   #12
chrismoore701
Did a little research and it is a little scary how bad it is to use radiator hose. I measured the od on tank and neck. And they are both 1 3/8". So I am good there. I just need to put it together and measure. Will keep you posted
Chris
Old 03-24-2016, 05:46 PM   #13
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I do not trust the aftermarket stuff so I looked until I found a New Old Stock Factory step side hose for my truck. It's far better than some of the weird rigged up ones I have seen
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 03-25-2016, 05:37 PM   #14
USSkoval
I cobbled mine together using a section of radiator hose, it was supposed to be temporary. But that was around 5 years ago now and it's still holding up great, other than hardening up some. I thought it would be lucky to make it a year but I was wrong.
Hopefully someone repops correct hoses soon.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 03-26-2016, 05:59 PM   #15
tucsonjwt
The flexible fuel line with a wire core will bend and keep a set very well. Most if not all cab and chassis trucks with utility boxes use this hose to connect to the fuel filler openings on the sides of the box.
Old 03-26-2016, 06:23 PM   #16
chrismoore701
Having a hard time finding 1 3/8" flex hose. Any idea where to get it?
Chris
Old 03-26-2016, 07:05 PM   #17
tucsonjwt
http://www.fillernecksupply.com/1-3-...sold-per-inch/
http://www.fillernecksupply.com/1-3-...hose-per-inch/
I would contact vendors to make sure that the hose you select will make a sharp enough bend to accommodate your application. The ones I have seen are very strong so it will take some muscle to make a sharp bend.
Also, if you have a local pick and pull junkyard with commercial utility body trucks in stock, you may be able to get a useable hose for a few dollars.
You can get 45 degree and 90 degree and 22 1/2 degree bends (I think) from Gates if you can approximate the bend you need. I used these on the dump box conversion on my 83. The hoses are very long and you just cut off what you don't need. With those 3 angle options, you can turn the sections of two hoses at different angles and join them with a short piece of filler pipe with large hose clamps. (Think plumbing fittings put together to fit a close quarter bend.) This will likely be cheaper (check Gates filler hoses on Amazon or Orielly Auto Parts) and you will get a smoother transition from tank to filler neck. You can find 1 3/8" filler necks and various angle filler hoses at the junkyard, so with some creative fiddling you can also get what you need that way.
Old 03-29-2016, 08:13 PM   #18
chrismoore701
I stopped by a hydraulic hose shop today. And they said to never get a hose with a steel coil in it as it will conduct static electricity and cause a fire. Just an FYI
Chris
Old 03-29-2016, 10:28 PM   #19
USSkoval
You just made me feel better about my crappy radiator hose as a filler hose.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 04-03-2016, 03:12 PM   #20
Pontiac1976
Pontiac1976's Avatar
I think LMC has filler neck hose ARE they any good ?
If you do have duel tanks do you not just buy two turn the hose around to fit the other side.?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-03-2016, 07:03 PM   #21
chrismoore701
I am going to go to a local hose shop and see what they offer first. I think I found them at classic industries.
Chris
Old 04-04-2016, 01:46 PM   #22
chrismoore701
What about using some exhaust bends with straight hose? I know I don't want metel in there but this is not complete connection
Chris
Old 04-04-2016, 04:23 PM   #23
wildwilly4x4
static wont build up if you have it all grounded. That's why there are ground straps to the filler neck. If it couldn't be metal, then the tanks wouldn't be made of metal. Think about whats going on with your filler system...
wildwilly4x4 is offline   Reply With Quote
Old 04-04-2016, 05:15 PM   #24
chrismoore701
Yes I know about the gas tank being metal, but I thought you want the tank isolated from the filler neck with a rubber hose, hence no grounding strap
Chris
Old 04-04-2016, 05:33 PM   #25
wildwilly4x4
No, rubber hose is there because your tank is mounted to the frame, and the filler is mounted to the body....allows for movement.
When you run a hydrocarbon through a rubber hose with no ground, static begins to build up as it flows. when you fill up with gas at the pump, static is building as the flow goes through the hose. Once the charge gets to the filler nozzle, if the nozzle isn't in good connection with your filler neck, a spark can jump from the nozzle to your trucks filler neck, potentially causing a fire.
Metal in your filler hose will be fine, just make sure you have a good ground at your tank, and at your filler neck.
