Old 09-24-2003, 04:53 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Looking for OE & Moog P/N's -Front Suspension
If someone has access to the GM part numbers and the Moog part numbers for the 71-72 1/2 ton front suspension with Power Steering, please help. I want to rebuild the front end with Moog and need the part numbers. I also think this would make a good FAQ.
.......................................GM Part Number.........Moog Part Number
Upper Ball Joints
Lower Ball Joints
Inner Tie Rod Ends
Outer Tie Rod Ends
Tie Rod Sleeves
Idler Arm
Pitman Arm
Upper Arm Shafts
Lower Arm Shafts
New Upper Arm Shaft Shims
Lower Arm Shaft U Bolts
Drag Link (if available)
This is what I need. If we make this a FAQ and someone has the info. list the same for NON Power Steering 71-72 and the 67-70
Rich
1972 K5 Blazer CST Click HERE
Old 09-24-2003, 10:56 PM   #2
slam33
slam33's Avatar
I use carparts.com they have all the moog #'s
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-25-2003, 09:54 AM   #3
mcmlxix
mcmlxix's Avatar
Talking
ok. I went the carparts.com route to find part numbers. Then I went to Summitracing.com for pricing and it came out to $520 for everything listed below. 71 c/10 with Power Steering
Lower Ball Joint, Enhanced Design 2 Required .........K6117T
Upper Ball Joint 2 Required .........K6124
Inner Tie Rod End 2 Required .........ES403L
Outer Tie Rod End 2 Required ..........ES415RL
Adjusting Sleeve 2 Required ...........ES2004S
Lower Control Arm Shaft Kit 2 Required ............K6147
Upper Control Arm Shaft Kit 2 Required ............K6098
Idler Arm, Improved & Enhanced Design 1 Required ...........K6096T
Pitman Arm, With Power Steering 1 Required ............K6131
Rich
Old 09-27-2003, 01:13 PM   #4
1971 Cheyenne
1971 Cheyenne's Avatar
I think that you can get the whole kit from Carolina Classics for around 490 dollars??? somewhere around there. I got my kit from Early Classic Enterprises and I paid around 525 dollars for it I think. Great service and fast shipping though. If you want a great experience, go with Early Classic.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 10-07-2003, 09:16 AM   #5
mcmlxix
mcmlxix's Avatar
I just orderd all the moog front end parts online from :
http://www.autopartsgiant.com/
They were the cheapest $465 with free shipping. (ground)
The only thing I didn't order from them was the tie rod adjusting sleeves. I found a billet set for $35. To me the originals just look weak. I know they lasted for the first 32 years but the billet ones look so much stonger, and nicer too.
Rich
Old 10-07-2003, 09:42 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Good luck with autopartsgiant.com. I have had a nightmare time with them. I ordered some Moog ball joints and other stuff for my truck. The 2 lowers were in the correct box but 2 different ball joints. I order 2 more, shipping & handling again. I send the first ones back(my dime) still no credit after a week. Im about ready to complain to the BBB.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-07-2003, 10:51 AM   #7
mcmlxix
mcmlxix's Avatar
great! now I'm scared. I trie buying them locally but they all wanted outrageous amounts of money. I was going to go with ECE or Carolina Classics but I found these guys on line and free shipping. Well I hope this turns out better then your experience. I usually end up screwing myself looking for the "best deal" !!
How did you ID the parts not being Moog? Are they stamped? I still have another 5-7 days before the parts arrive..... i hope .. i hope .. i hope ...
Rich
Old 10-07-2003, 11:41 AM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Hopefully you have better luck than me. Be sure to check everything as soon as you get it. I waited till I was ready to install and then found out. They were Moog parts, just two different ones.
ZIP 91351
Old 10-08-2003, 10:21 PM   #9
loweredd
www.loweredd.com
loweredd's Avatar
We sell MOOG at work. If you buy over 4 parts, you get a 10% discount. I bet I beat all others prices.
loweredd is offline   Reply With Quote
Old 10-08-2003, 10:23 PM   #10
loweredd
www.loweredd.com
loweredd's Avatar
dang it I wish I got comission. LOL. I love selling parts to people for cheap. I only wish when I called other places, they wouldn't hose me.
Old 10-09-2003, 12:13 AM   #11
boraxman
Keepin an eye out
boraxman's Avatar
If only I knew.
ZIP 91351
Old 10-09-2003, 12:18 AM   #12
loweredd
www.loweredd.com
loweredd's Avatar
hehehehehe
Old 10-09-2003, 12:25 AM   #13
mcmlxix
mcmlxix's Avatar
Well I already placed my order so DONT tell me if you can get them cheaper .... ....
Rich
Old 10-09-2003, 10:45 AM   #14
loweredd
www.loweredd.com
loweredd's Avatar
ROFL, OK.
Old 10-09-2003, 03:03 PM   #15
Canada20
so what does "improved design" refer to in the patrs mentioned above? Improved how?
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 10-15-2003, 12:49 PM   #16
cwilli84
1FINE69
cwilli84's Avatar
Mother truckers has a complete set from Moog also. Good stuff and great service.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 10-21-2003, 08:54 PM   #17
Linus0014
Guest
Posts: n/a
edelbrock makes a set of adjusters that look pretty nice to me.
Old 10-21-2003, 09:00 PM   #18
boraxman
Keepin an eye out
boraxman's Avatar
Does anyone know if the Moog ball joints are prelubed? Seems like theres some lube but do they need more?
ZIP 91351
Old 10-21-2003, 11:00 PM   #19
loweredd
www.loweredd.com
loweredd's Avatar
you need to "top them off" with grease when you get them all installed. The lube that's in there is mainly to stiffle rust as it sits on the shelf.
Old 10-21-2003, 11:30 PM   #20
boraxman
Keepin an eye out
boraxman's Avatar
Thanks.
ZIP 91351
