Need help with bed caulking
What kind of caulking do I use on bed floor and bed side.
Re: Need help with bed caulking
Seam sealer. You can usually find it at any of the regular parts stores.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
3m seam sealer.
Thanks guys.
The 2 times I have bought seam sealer in my life it has been dried out and stiff and hard to spread; almost like bondo that is has hardened too much to spread smoothly. I don't know what good seam sealer even looks like but I don't think it is supposed to be that way. I think it sits on the shelf too long until somebody finally buys it. I always figured it should be creamier like nice soft bondo. I only mention this because you may need to buy more than one can to find a fresh one. Somebody correct me if it is supposed to be that way.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#6 | |
Do you put it on after you put the bed side on or before ?
Thanks for that tip cshades. Next time I will buy it in a tube.
I have always cleaned the area its going applyed the seam sealer and painted over it.
The areas that are going to be seam sealed should be cleaned and painted or epoxy primed before the seam sealer goes on and then the whole inside of the box can be painted after. I try to keep the rust from growing under the seam sealer and if you do not treat the areas under the seam sealer it will get rusty at least in this state with all the salt and chemicals they dump on the road.
Let me ask you where is the spot weld on truck bed fender at exactly that needs to be spilt
79 Chevy 2wd BIG10 350 TH400 |
#13 |
I got seam sealer from the auto paint store in a caulking cartridge. It was pricey (about $20) but it was soft and firmed up nicely after a week or two.
#14 |
I had to replace one side panel in the 70's and I used house-grade caulking. Bought it from the home supply or local hardware store. It's still there and in place. I'd buy a premium quality however.
#15 |
![]() Join Date: Jun 2009
The only place there is a tack weld at all is at the rear stake pocket at the floor. Usually there is a tack weld on each side of the stake pocket. So two tack welds
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#16 |
The one I am doing has 2 tack welds on each side at the rear stake pocket. I suppose it depends on what year they are or what factory they were made in.
#17 |
good info in here. I'm raising my bed floor soon so I will need this stuff too.
#18 |
STILL PLAYS WITH TRUX
X2 You have to go to a GOOD Auto paint shop/store to get GOOD seam sealer this is because they sell ALOT of it! The auto part's store's don't n who know's how long that stuff has been sittin there.
