Old 03-15-2016, 12:32 AM   #1
Isaiah92260
Isaiah92260's Avatar
Question about 67' dual master swamp
I've read the sticky about the swamp and some other threads.... But do have a question. I got a 67' dual master, gonna install into my 63.... It's pretty clear that my brake pushrod is going to work and won't have to worry about that, now after sourcing all the right Brass Adapters for the piping, but once that is all put together... I'm confused on which 2 of the ports are for which Brake lines.. The back port closest to the firewall is a 5/8s port... And the front is 9/16th.... I can see by eyeball on the pictures from other threads my ports are reversed, looks like the other MC they have got a 5/8s port on the front.... Maybe I am over thinking but I am going to attempt to do the swamp after work and be able to drive my truck the next day, so I want to be sure on the procedure... If anyone can help me I would greatly appreciate... Thanks a ton for reading!
Isaiah92260 is offline   Reply With Quote
Old 03-15-2016, 06:33 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Question about 67' dual master swamp
Are you disc/drum or drum/drum?
For disc/drum, the larger port and reservoir go to the front brakes.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-15-2016, 07:52 AM   #3
patrickk1
what's a dual master swamp?
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 03-15-2016, 08:01 AM   #4
chevy2tom
chevy2tom's Avatar
Separate reservoirs for front & rear brakes. Typical master cylinder. If you're drum drum try one from a impala or chevelle from the 60's
chevy2tom is offline   Reply With Quote
Old 03-15-2016, 08:55 AM   #5
Isaiah92260
K
It is a Drum/Drum.
Old 03-15-2016, 11:18 AM   #6
Rust-O-Matic
Rust-O-Matic's Avatar
Like Keith said, the larger port and/or reservoir go to the front brakes.
I used a '68 drum-drum cylinder on my '66. One port was 1/2", one was 9/16". I plumbed the larger port to the front brakes, and it works like a champ.
No need to fool around with cylinders from other applications, or make this any more difficult than necessary.
Rust-O-Matic is offline   Reply With Quote
