03-15-2016, 02:43 AM | #1 |
cab sails
hey guys i have some of the best friends a guy could ask for .. and they found me some nice looking aluminum cab sails at the local auto swap meet . anyway i need the clips that they snap on to ... would you happen to know where i can get these clips at ?
03-15-2016, 09:58 AM | #2 |
Re: cab sails
I don't think they sell them separate from the moldings .
you can make them they are 6 1/4 X 1/2 inch with a hole in each end for the screws to attach them to the cab. one of the long sides is bent so the molding will slip under it . |
03-15-2016, 10:52 AM | #3 |
Re: cab sails
think you can get them from lmc
ron |
03-15-2016, 11:28 AM | #4 |
Re: cab sails
Looks like LMC just sells the screws. Those are hard to find and even harder to get loose if ya find em on a trk. Probably make em like mentioned earlier. I have a set someplace if ya want I'll find em and take a pic. I would like to put mine on but the screw location and holes are a bit tricky. the little screws holes are threaded for reg. counter sunk super tiny stove bolts. I guess ya could use a sheet metal screw. I think it's goin be hard to figure where the strips go . anyway let us know how ya do.
03-15-2016, 12:09 PM | #5 | |
Re: cab sails
03-15-2016, 01:25 PM | #6 |
Moderator
Re: cab sails
Thats why I've never installed any. There really isn't any good info other than the assembly manual, but that doesn't show the bracket/clips they use. And conducting a search hasn't brought that information to light. I will be subscribing.
03-15-2016, 04:37 PM | #7 |
Re: cab sails
Drop Lyle BLK65K10 a pm - he may have another set..
http://67-72chevytrucks.com/vboard/s...d.php?t=696728
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
03-15-2016, 05:36 PM | #8 | |
Never Ending Projects
Re: cab sails
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
03-15-2016, 05:39 PM | #9 |
Re: cab sails
03-15-2016, 05:39 PM | #10 |
Re: cab sails
Balls! Sorry Mike - feel free to delete my post.
03-15-2016, 05:55 PM | #11 |
Re: cab sails
Learning experience for all.
It's all good, no worries.
03-15-2016, 06:57 PM | #12 |
Moderator
Re: cab sails
I thought it was Ballocks?
03-15-2016, 10:35 PM | #13 |
Re: cab sails
sail tabs
03-15-2016, 11:52 PM | #14 |
Re: cab sails
03-16-2016, 01:16 AM | #15 |
Re: cab sails
first, the double sides tape will probably work I used it to see if I liked the sails on my trk. second, I think a guy could make those rails. they just need to be bent all the way along one side so you can slide the sail over and then the two or three screws that hold it to the inside of the door/cab frame hold it in place. the rails just go out on the side of the cab so ya can't see the screws.
03-16-2016, 01:19 AM | #16 | |
Re: cab sails
03-16-2016, 03:29 AM | #17 | |
Re: cab sails
The automotive tape is what I will do, as the sails are lightweight. I have some nasty ex factory tape and it sticks like mad. I am sure you will be fine either way.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-16-2016, 09:10 PM | #18 |
Re: cab sails
they are so ez to make . all you need is 2 pair of visegrips to bend them.
or if you cant bend one side up so the molding will slide under it then just make them flat and put tiny washers between the brackets and the body to space them away from the body so the molding can slide under them. they don't have to have the fancy bends like the factory ones in the picture . you can even use aluminum and they don't even have to be 6 1/4 long they can be shorter no one can see them after your moldings are on. |
03-16-2016, 10:36 PM | #19 |
Re: cab sails
here is some info on how to mount the sails without the original clips
http://67-72chevytrucks.com/vboard/s...d.php?t=497542 http://www.chevytalk.org/fusionbb/sh...58/tid/270929/ hope it helps |
