03-15-2016, 10:53 AM | #1 |
Anyone using an aluminum brake m/c?
I'd like to use a Mopar style brake m/c and am wondering if anyone has taken this approach. There was an early posting by Pyrotechnic on doing this, but there was never any follow-up if it worked or not. Thanks
03-15-2016, 11:01 AM | #2 |
At the body shop.
Re: Anyone using an aluminum brake m/c?
I just ordered on for a 85 , aluminum body and plastic Reservoir
" That didnt make it any newer " " Dont antique the equipment " |
03-15-2016, 11:03 AM | #3 | |
Make sure the rear of the master cylinder fits inside your booster; the QTU ("quick take up") master cylinders are larger in diameter than the non-QTU units. Also make sure you plumb the larger port/portion of the reservoir (regardless of whether its in the front or rear of the master) to the front discs. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-15-2016 at 11:09 AM. |
03-15-2016, 10:37 PM | #4 |
My (Canadian) '83 C10 and '81 GMC both came with the aluminum master.
Alex. |
03-15-2016, 11:42 PM | #5 |
Just curious - why the Mopar one and not an aluminum GM one?
03-16-2016, 01:21 AM | #6 |
you will have to make your on line or at least change the ends at the master metric 81-87GM fitting the 73-80 are SAE fitting, Unless you change the proportioning valve same YR. brake down then make half and half brake line to the rubber lines.
There two sizes small reservoir. or larger reservoir. the one in the pic above looks like the larger one.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-16-2016, 03:03 AM | #7 | |
At the body shop.
http://www.dormanproducts.com/itemde...&SEName=m39589
03-16-2016, 06:08 AM | #8 |
My reason for wanting a Mopar piece is purely aesthetic, and bending/reconstructing brake lines is easy to do, since that was one of the daily repairs done to many a truck at the repair shop I worked at, here in New England (Thank you D.O.T.). Currently I have a cast iron Corvette/Chevelle unit that does its' thing well. I like it better than the boxy unit that came from the factory. But, being that it's cast iron, it loses its' nice cast color and slowly turns to oxide red, and when I open the hood to show off the 5.3L, the first thing you see is the rusting M/C. I don't want to paint the M/C, because when fluid gets under the paint and starts to "lift" it , it's ugly. I'm a little leery about powder coating, afraid that maybe some sand would get into something (sandblasting, part of the pre-coat process). BTW, my truck is an '80, so it isn't equipped with the QTU system
It's not like my truck is a show piece. It ain't. It's just a "driver". I just want it to be neat and clean |
03-16-2016, 11:40 AM | #9 |
could switch to syn. brake fluid,it,s not supposed to eat paint
03-16-2016, 12:06 PM | #10 | |
Moderator
Be careful. Some clown decided it was a good idea to use the same naming scheme for Silicone as Glycol so there are two DOT5 fluids. DOT5 is Silicone DOT5.1 is the latest generation of Glycol. If you have Glycol DOT3, DOT4, DOT5.1 keep it. If you want to upgrade your brake fluid to higher wet boiling point go to the next higher Glycol fluid number. Maintenance is key. Flush the system with fresh new fluid every 2 years and you will have zero issues with Glycol based fluid.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-26-2016, 01:56 PM | #11 |
This is probably what you are talking about. I have had this setup for 4 years and works great. I have 4 wheel disc, the master is for a dodge shadow shelby iirc because they came with 4 wheel disc. Takes regular 3/16 brake line and 3/8-24 fittings, modified push rod and cost like $24 at autozone. One inch bore size.
03-26-2016, 04:11 PM | #12 |
Yeah, that's the one (or similar to it). What's different with my truck, though, is it has power brakes, so I'd need a larger cylinder bore (1 1/8), and the piston would be different. Whereas yours has a deep impression to hold the brake pedal pushrod, a power m/c has just a dimple for the booster pushrod to push against. Making a bullet to fit the deep piston wouldn't be a problem. My concern would be the Mopar mounting footprint and whether or not it would fit within the power booster orifice. BTW, nice plumbing on your set up and I see you have a hydraulic clutch as well
03-26-2016, 04:59 PM | #13 |
Yea I have always liked manual brakes, especially with the stick. This one has the T56 and without the booster you can just line up a wilwood type master with the stock clutch pedal and works out real nice. With this master and the stock brake calipers (rears are stock ford sliding single piston same size as the fronts) it really doesn't take much pedal effort at all to stop. Even towing my car trailer with a 4000 pound car it ain't bad. Seemed kinda weird using a master from a tiny little car but piston size and pedal ratio vs caliper size all worked out in my case.
If you want to stay with the power booster maybe you could just use the mopar booster? Maybe one from a small car would be easy to adapt?
03-26-2016, 10:02 PM | #14 | |
http://www.speedwaymotors.com/Shop/Speedway/11.html
I can still count my vehicles on two... wait three hands. |
