Old 03-15-2016, 11:44 AM   #1
cruisinthe34
cruisinthe34's Avatar
Rear sway Bar ????????
This is my first c10, and I just ordered a FRONT sway bar, is there a need for a rear sway bar on these trucks ?? I'm just trying to build a nice streetable inline 6 truck.
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 03-15-2016, 12:05 PM   #2
XwalkerX
Re: Rear sway Bar ????????
Well you typically order the sway bar for the opposite side of the truck you want handling to improve on. The lower you go, the more you will get out of the sway bars.
Sway bars transfer the load from the outer side wheels to the inner side wheels to keep the chassis leveled during cornering. The way they are designed, the lower you go, the more tension you're gong to put on them, thus working harder when you are cornering. The downside is that too much tension could snap the end link plates.
For me it was a no brainer and I ordered front and rear since it was only $200 shipped for both.
XwalkerX is offline   Reply With Quote
Old 03-15-2016, 12:11 PM   #3
CC69Rat
CC69Rat's Avatar
Just my .02, unless you're going to be doing any racing, or running cones at the shows.. then not really a need for a rear swaybar. If the truck is lowered, as mentioned that helps a lot and you'll notice a substantial difference with just the front sway bar.
I have driven both and there is definitely a difference with the rear sway bar.. but is it really necessary for a good street driven 6cyl 3ott weekend driver? .. not really. I'd save my money and just replace the trailing arm bushings (unless you have already) that will help a bunch too.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-15-2016, 12:36 PM   #4
68 P.O.S.
I did a front end and suspension overhaul on my truck, so added both sway bars since I was already doing the work. Both sway bars made big difference, it feels like I'm driving a Camaro now. Hahaha. Is it necessary? Maybe not, but a lot of new vehicles come with them now, and not just cars. I would do it again in a heartbeat. I also added a steering stabilizer too, but the need for that is far less than a sway bar.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-15-2016, 12:45 PM   #5
cruisinthe34
I ordered my front Stabilizer from ECE. Stan doesn't carry a rear stabilizer bar. I suppose I could check Chassis Engineering Inc in Iowa...... Any recommended source for the rear bar ???
Steve
Old 03-15-2016, 01:41 PM   #6
68 P.O.S.
My front sway bar came from ECE too. From what I read on here, Stan doesn't believe our trucks need a rear bar so they don't sell them. I purchased mine through CPP. The install for both bars was easy enough and they work well together.
Old 03-15-2016, 01:44 PM   #7
davepl
davepl's Avatar
I put the generic LMC one on mine. I didn't drive it much beforehand, so a comparison is tough, but it does stay pretty flat in turns compared to other ones I've owned.
Necessary? No. Helpful? Seems like it. Downsides? Not so far.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-15-2016, 02:26 PM   #8
Ekliptix
Ekliptix's Avatar
Recent discussion about this exact subject: http://67-72chevytrucks.com/vboard/s...d.php?t=538484
Ekliptix is offline   Reply With Quote
Old 03-15-2016, 02:44 PM   #9
XwalkerX
I bought my CPP F+R sway bars through summit when they were on sale for $200 with free shipping...
Old 03-15-2016, 03:37 PM   #10
88Stanger
88Stanger's Avatar
good info. may need to check on a 198os Camaro sway bar.
88Stanger is offline   Reply With Quote
Old 03-15-2016, 06:55 PM   #11
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Hellwig and ADDCO also make bolt on rear sway bars.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-16-2016, 06:32 AM   #12
cruisinthe34
Just ordered the LMC Rear Sway bar to go with the ECE Front sway Bar. I'll try to report on the setup. It will be a while though.
Steve
