Old 03-15-2016, 01:31 PM   #1
RodsGreen10
RodsGreen10's Avatar
Wilwood Rear Disc Conversion
Looking at buying the 2 piston rear kit for my 76. My question is will any other brand rotor work with that kit or am I stuck buying Wilwood rotors. Will 92-02 Chevy Astro AWD front rotors work? Or anything beside Wilwood. I know it comes with a rotor. But I want to know if I have a option of using something different.
RodsGreen10 is offline   Reply With Quote
Old 03-16-2016, 07:57 AM   #2
andrewmp6
Re: Wilwood Rear Disc Conversion
I believe your stuck using their stuff,Have you looked at other brands ?
andrewmp6 is offline   Reply With Quote
Old 03-16-2016, 09:06 AM   #3
RodsGreen10
Hmm. No I haven't yet. The reason I looked at them is because of the matching front calipers that would match the rear. I don't want to do a big brake upgrade. I need to replace my front calipers and want to do the rear conversion. But I want calipers matching front and back. Plus the rotors matching. Lol. If it does not match it will drive me crazy lol and I just won't do it. Any other suggestions?
Old 03-16-2016, 11:01 AM   #4
RodsGreen10
I am assuming that Wilwood and others on the market must be using a rotor off of another model. I just don't see them making a special rotor for 1 specific kit. But I might be wrong.
Old 03-16-2016, 12:23 PM   #5
bbbc10
Diggin The SquareLife
There is a guy on here that sells the rear bracket conversion for our trucks an he also has the rear calipers an rotors also
bbbc10 is offline   Reply With Quote
Old 03-16-2016, 12:29 PM   #6
RodsGreen10
Yep Captain Fab. Good guy I have delt with him before. Also need to decide if I want to utilize a e brake.
Old 03-16-2016, 12:32 PM   #7
PGSigns
PGSigns's Avatar
Most states require the ebrake to be there and working. May want to check that.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-16-2016, 12:34 PM   #8
RodsGreen10
Jimmy
Not a daily driver. And no interceptions here. Not worried about Johnny Law.
Old 03-16-2016, 12:39 PM   #9
ptc
ptc's Avatar
Year, make and model of other vehicles doesnt really matter. The only thing that matters is the correct rotor diameter and the correct rotor thickness. You can use any rotor that meets those specs. NO you shouldnt have to use Wilwood rotors with their calipers. Just make sure that you shim it per their specs for whatever you use. Shimming it centers the caliper on the rotor so that you get equal pad wear. This is ciritical with any application.
Enjoy!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-16-2016, 12:44 PM   #10
RodsGreen10
Yep same rotor specs. Just easier with the parts store rejects giving them what they ask for all the damn time lol. Forgot and color lol.
Old 03-16-2016, 01:02 PM   #11
ptc
ptc's Avatar
One other thing about Wilwood calipers is you need adapters for the brake line connection, they are a different thread than just your reg flared end. Its good to use flex lines anyway to all calipers and not just a hard line connection.
Old 03-16-2016, 01:15 PM   #12
RodsGreen10
I got that covered. Thanks
Just get this rotor thing figured out and I will be golden.
Old 03-16-2016, 01:30 PM   #13
RodsGreen10
Or maybe if I can find a front rotor that matches the Wilwood rotor exactly that might be easier. Same pattern with the slots and drilled holes. I just don't want my rotors to be different and look ghetto. Lmao.
